Level Crossing speed restrictions
Derek Kaye
9 Jun 2005
Loughborough
Could anyone help me with this?
if you have a level crossing speed restriction board (i.e a white rectange with an 'X' at the top and the speed underneath) will this sign
a) have AWS associated with it
b) where does the restriction start? at the restriction board or at the crossing?
c) where does it end? is there a normal line speed sign after the crossing, e.g. 60 or does it go back to the previous speed when the whole train has passed the crossing or just the front?
Simming
8 Jun 2005
Cornwall
a) no
b) starts at the bored
c) its ends once the loco has crossed the crossing, it only goes slow so it can be seen by car drivers, but once the train has started crossing the crossing, its can speed up, as it is already clearly seen from the car driver
Met Driver
8 Jun 2005
b) The restriction applies to the crossing itself, so it does indeed start at the crossing, not the sign.
c) Normal line speed can be resumed after the crossing. There is no sign to indicate this. In experience, the driver will usually apply power as soon as the front of the train passes the crossing, but I'm not sure if that's the correct procedure.
As for a), I'm not sure. I don't think there is on the Gunnislake and Newquay branches, but these could be exceptional cases.
Simming
8 Jun 2005
Cornwall
modern signalling handbook said:
the train driver is warned that he is approaching a locally-mointored crossing by a board bearing a black st georges cross on a white backgroud. he must then reduce his speed so that he can pass a speed restriction board at the appropiate speed
Met Driver
8 Jun 2005
I have another source which suggests otherwise (I hope). I'll try to dig it out.
Tomnick
10 Jun 2005
The restriction begins at the speed restriction board itself - so that the train is travelling at an appropriate speed to stop short of any obstruction on the crossing. The driver may open up as soon as the front of the train is on the crossing, I believe.
Met Driver
8 Jun 2005
Bonnie Prince Charlie said:
The X on the white rectangle board with the speed limit, is speed for crossing the LC when wrong line running
I've never heard that one before! What's your source?
bunnahabhain
8 Jun 2005
I've heard that one before, I think it's just Magazines/Websites where most people get all their information, I'm the sort of person that loves to get Information ;)
Simming
8 Jun 2005
Cornwall
That Applies to AHB-X which are AHB crossing that can still work automatically when trains are running wrong line. the Boards show something like : X30 for these.
Met Driver
8 Jun 2005
Cheers for that. It makes sense to me now!
11 Jul 2005
Or from working on the railway
Derek Kaye
9 Jun 2005
Loughborough
I saw a couple of X30 between Didcot and Banbury this afternoon on the wrong line. that makes sense. when its right direction its more like
X
30
or
X
15
20
i've seen
23 Jun 2005
Gateshead
