The line between Farnham and Alton is closed due to embankment issue and forecast of rain. This is until 19 April at the earliest.
South West Trains say last bus from Farnham is at 22.00 but the last train that usually runs from Woking is at 0.40.
National Rail Enquiries App says it's until end of service.
Would SWT be allowed to finish services earlier or do they have to provide rail replacement transport?
A it involves week days, they did well to find buses for the replacement service.
http://m.journeycheck.com/southwest...=&savedRoute=false&incidentsType=LINE_PROBLEM
Sent from my SM-G925F using Tapatalk
Cancellations to services between Alton and Farnham
Due to emergency engineering works between Alton and Farnham the line is blocked.
Impact:
Train services running to and from these stations may be cancelled or revised. Disruption is expected until 23:59 19/04.
Customer Advice:
There will be a temporary closure of the line between Farnham in Surrey and Alton in Hampshire from Wednesday evening due to an ongoing embankment issue. An emergency speed restriction has been in place on this section of track since 1 April and this was further reduced from 20mph to 5mph following a track inspection. There is a risk of forecast rain exacerbating the problem so the decision has been taken to close the line to identify what repair work needs to be carried out and to allow the work to take place. As soon as we have identified what repair work needs to be done, we will be able to confirm how long the line will need to be closed for.
The line between Alton and Farnham has now closed as of 21:00 on Wednesday 13 April to allow work to be carried out to repair the embankment. Replacement bus services will run between Farnham and Alton in both directions providing a service between Farnham, Bentley and Alton. Due to their size they will not be able to serve Bentley station, but will instead stop in the village to pick-up and drop off passengers. Buses towards Alton will stop outside the Memorial Hall, while those going towards Farnham will stop outside the Star Inn.
We will continue to update this message as the work progresses, and once we have an accurate estimate on when the line between Farnham and Alton will re-open we will let you know.
Any customers travelling from Bentley station, please press a help point on the platform for assistance.
Alterations to train services will be available to view at www.journeycheck.southwesttrains.co.uk
We are sorry for the disruption to your journey.
Replacement bus services are conveying passengers between Farnham and Alton in both directions until further notice. -
The buses towards Alton depart Farnham at 00 and 30 minutes past each hour and depart Bentley village Memorial Hall at 10 and 40 minutes past each hour.
The first bus departs Farnham at 0630 and the last one at 2200.
The buses towards Farnham depart Alton at 25 and 55 minutes past each hour and depart Bentley village Star Inn at 35 and 05 minutes past each hour.
The first bus departs Alton at 0525 and the last one at 2125.
Additional Information:
If you would like to make a comment or give us some feedback about your experience with us today, please email us at [email protected], 0345 6000 650 (option 4) or fill in the contact us webform http://po.st/ContactSWT
Have you been delayed by over an hour ? Please see here for information about compensation - http://po.st/SWTCompensation
Further Information :
An update will follow within the next 1 hour.
Message Received :14/04/2016 07:50
