Change "thought" to "were instructed that", and you'd not be wrong.
This "improvement" was brought to you by the letters D, F and T.
The ATW 158 refurbishments were funded by the Welsh Assembly so presumably were to their specification.
Leeds-Norwich could work very well but would the demand be sufficiently balanced across the journey, especially with a separate Liverpool to Nottingham service.
I didn't know the Northern EMU was a franchise requirement. The TPE Scotland service will surely be running via Bolton by then but who knows with Network Rail! It is 15 minutes faster which is a considerable saving and much needed.
Thats the sort of idea that would make a EMT regional fleet of all 158s appealing because there would be huge flexibility of choice of services and in timetabling.
The rumour on social media appears to be that TPE would use Mark Vs. If Northern took over the route then 158s would be adequate but 195s better. EMT also use 156s for the service because they have insufficient 158s therefore transferring enough 158s to run the service from December 2021 would cause other services to be downgraded while the intercity services will be stretched prior to the arrival of new stock. Its a little odd that the regional express opperator does not run a service between Liverpool and Sheffield and only has 1tph between Manchester and Sheffield. I am doubtful that the government will want to make any alterations to the Northern franchise agreement to add or remove services or rolling stock. It would be opening a huge can of worms!
I suspect whoever runs this service it will involve the 185's either Northern or TPE use the 185's on the route, or TPE use the Loco Hauled Stock and use the 185's to replace the Loco Hauled stock on the TPE North route, which to me makes a lot more sense, the Loco Hauled stock having served the purpose of increasing capacity quickly it then makes more sense to only 2 types of train instead of 3 on the busy Northern Route.
Although would TPE's loco hauled stock increase capacity? Going from 4 car 158's (assuming there aren't unit shortages) to 5 coaches, 1 first class.
Yes it will include first class and be more 'intercity', but would the standard class seats increase, which I expect most people will care about.
I could be wrong as I can't remember the numbers. I'm sure somewhere I saw that a 3 car 185 doesn't have 'that' many extra standard seats than a 185 and with it doubled there's no corridor connection.
But then will Nottingham to Liverpool take all of the LHCS? Or are you proposing its use on the Cleathorpes service as well?
Does it nessesarly have to increase capacity if there going capacity for an additional Fast Train per hour between Sheffield and Manchester, and also if EMT run the Norwich up to Sheffield which is an option.
I forgot about the third hourly fast service as that will improve Sheffield to Manchester a lot
These services finished in 2003 as part of the Strategic Rail Authority's obsession with removing virtually ALL Liverpool's long-distance services from the timetable. Also disappearing round about the same time were the sporadic services to Scotland, Thames Valley, South Coast, South West and South Wales. Some - but by no means all - of these cuts are now being reversed. But the West Midlands service, once a key Inter-city route, remains in the hands of commuter-esque rolling stock with 3+2 seating and far too many intermediate stops (Acton Bridge, Winsford, Penkridge, Coseley) and Liverpool is now far and away the biggest English city that doesn't have a regular two trains per hour service to London.It wasn’t so long ago that it was Liverpool Lime St to Stansted Airport with the odd one going to Cambridge only. 158s. Can’t remember where they went via. Was this the early 00’s?
This is all about Grayling/Dft finding something for the 185 fleet at Ardwick to do. They even acknowledge that in the consultation 65% wanted the Liverpool-Norwich to stay as it is, so I don’t think it’s about improving the service for users.
Places such as Chinley, Widnes, Liverpool South Parkway are only 4 car Platforms, could the 185’s be reformed into 4 car and 2 car sets ?
I've thought there must be something going on here for a while. The DfT much as they'd previously consulted never accepted the outcome that people didn't want the service split, that, coupled with TPE refurbishing all the 185s when they'd not planned to keep them all has long said to me that there are loose ends.
Agreed. There is a fleet of modern trains needing a home. While we'd like to have the idea the DfT are not intervening and directing rolling stock this does appear to be a factor here.
Didn't the CLC route see 6 car 185s up until the last timetable change? Surely that means Liverpool South Parkway isn't a problem?
They've ordered Northern to combine the Crewe to Manchester and Manchester to Liverpool into one service which doubles up as a long distance route and commuter service into both Manchester and Liverpool. The performance on this route to date has been a shambles and a total failure.
Yet they want to the replace the one long distance intercity service which actually works well and serve a purpose.
It's just madness...
If the plan to cut back the Liverpool Lime Street to Norwich service to start at Nottingham, could this be a future plan to extend it to Birmingham New Street?
- 20:31 left over seven minutes late (the 20:31 terminates at Manchester because EMT run ECS back from Liverpool in the evening since they don't have a depot, so there's no services later than 19:40 from Sheffield to Liverpool - another thing that a change of TOC may change)
But then will Nottingham to Liverpool take all of the LHCS? Or are you proposing its use on the Cleathorpes service as well?[/QUOTE k
I entirely agree. Whatever the source (XC, EMT, GA, whatever), Cambridge urgently needs more than 1tph to Peterborough. If that happens to be a service that also goes to Nottingham, and perhaps even Sheffield, I fully expect a lot of people to be rather attracted to that. Currently having to change at Ely to do this - even when the connection is pretty good - puts a lot of people off.
But you move the problem from one end of the route to the other. TPE may well have a depot in Liverpool but they don't have one in Nottingham and as far as I am aware they don't have one in Sheffield either. So how do you cover the 00:40 arrival at Nottingham from Liverpool and the 05:20 departure from Nottingham to Liverpool? (amongst others)
Thats whay I argue XC would be better as the operator of choice as they have a depot in Manchester for the Liverpool starters and would clearly get all the drivers in Norwich. Also its a cross country route so aligning it with the Cross Country franchise seems a better fit to me.
Presumably some drivers and guards would TUPE over from EMT to the new operator at handover, all of whom will be Nottingham based. Thus may end up creating a small satellite depot in Nottingham.
How do TPE currently deal with the late night terminators at Cleethorpes?
It might be why Northern would be a better fit as they will also be running Northern Connect Services there in the next few years.
On the loco-hauled sets the DVT carriage will only have First Class seats so they'll still be 4 x 23m carriages with standard class. However, as these carriages will have a more Intercity style interior - more tables, more luggage space, more toilets, better facilities for preparing there won't be as many seats in total - 257 is the minimum number given in the franchise agreement, it might end up being slightly more.
Fourth point is that the train has the following number of seats: 64 in the DT, 59 in the next coach, 69 in each of the next 2 coaches, then 30 first in the remaining coach.
