Living on SWT outside London...?
Coxster
9 Jun 2005
...the signaller's strike will kill you ;) I'm alright with a train every half-hour though. On the WHOLE of SWT's network the following will run (as quoted from another forum).
SWT intend to operate a skeleton service if the strike goes ahead this Friday:
2 tph Waterloo - Kingston via Wimbledon
2 tph Waterloo - Kingston via Richmond
2 tph Waterloo - Staines via Hounslow Loop
2 tph Waterloo - Staines via Richmond
2 tph Waterloo - Basingstoke
2 tph Waterloo - Bournemouth
2 tph Waterloo - Woking
(The same trains?)
1 tph Waterloo - Sailsbury
That means no service to Guildford, Haslemere, Portsmouth
That means no service to Poole and Weymouth, or services West of Salisbury
That means no service to Brighton or Reading
T
Tom
Guest
I would actually presume that Southern would operate Southampton Central to London Victoria via Portsmouth Harbour and Brighton.
Coxster
9 Jun 2005
Yes but at what frequency?
Lewisham2221
23 Jun 2005
Staffordshire
Remember that this is a signallers strike, not a train crew strike. Therefore would it not make common sense to presume that where one operator is unable to operate over a particular line, the same would apply to other operators, namely because of lack of signalling staff presence?
T
Tom
Guest
It would be more an issue for SWT to get trains out of the depot as Eastleigh box would be understaffed presumably - so just straight through services would be helpful for them ... with the odd Southern to Soton.
Andrew
7 Jun 2005
Southern and Southeastern alterations are up. No trains to Portsmouth it looks like (though I've only skim read). Southern (as a region - ie SWT, SN and SE) looks very badly hit (apart from Island Line!).
Possibly - but if they are manning some 'boxes with less signallers - rather than no signallers - then reduced frequencies will result.
