LM Advance Singles - starting at later station
nuneatonmark
5 Aug 2014
I have two advance LM only singles for a return journey Nuneaton/London/Nuneaton. I would now like to start and return to Rugby, both services stop at Rugby, am I allowed to do that?
No, you are never allowed to do that on Advance tickets, you must make the complete journey shown on the ticket.
185143
3 Mar 2013
I'm assuming you mean Advance and not super off peak/off peak/anytime singles you have bought in advance?
Sent from my SM-G920F using Tapatalk
sonic2009
19 Jan 2010
Crewe
As previous advice offered then you must travel to the points specified on your ticket.
bb21
Emeritus Moderator
4 Feb 2010
Are both legs on the same day? An easy workaround is to purchase a Rugby - Nuneaton return if so. On the return leg you can simply ask the guard if you need to travel all the way to Nuneaton and back, and will probably be told not to be stupid. On the way out is a little tricky, and actually travelling to Nuneaton and then back is the safest option. I can't realistically though see any guard taking an exception if you simply boarded at Rugby and showed him the ticket to Nuneaton and the Nuneaton - London ticket together.
If not on the same day then two singles instead of a return would be needed, so a bit more expensive, but that is the safest thing I can think of.
Mag_seven
1 Sep 2014
here to eternity
Can't help but thinking that that defeats the whole purpose of the exercise.
nuneatonmark
5 Aug 2014
Thanks guys for the info. I wouldn't want to fall foul of the rules and simply board at Rugby if there's no barriers (I am sure someone would spot that) or buy a return to Nuneaton just to get through the barriers and board the train, that wouldn't be cricket would it!
