LM Crewe-Euston on Monday 25th
Discussion in 'Allocations, Diagrams & Timetables' started by 185143, 22 May 2015.
Thread Status:
    185143 Established Member
    2,753
    3 Mar 2013
    Looking at travelling on the 06:52 Crewe to Euston on Monday. Is this possible to get a 350/2 on? If so, what is the 06:49 via the West Midlands likely to be? I'm assuming the :49 will be a /2 and :52 a /1 or /3. Certainly hope so!:D
    Rail Forums
  3. tcm1106
    tcm1106 Member
    240
    4 Jan 2010
    Rugby
    0652 is nearly always a pair of /1s and the 0649 is usually a /2 I believe.
  4. 185143
    2,753
    3 Mar 2013
    Good. Most /1s are required and /2s to Euston? No thanks!!
    Thanks for the quick response :)
  5. sd0733
    sd0733 Member
    929
    7 Nov 2012
    As has been said the 6:52 is booked a pair of /1s but due to bank holiday on monday will ptobably be a single. The 6:49 goes through to EUS and is also booked a /1 as it then goes and forms the 1046 euston-crewe fast.
  6. Bletchleyite
    Bletchleyite Veteran Member
    26,611
    Up and down the south WCML (mostly)
    Which platform do they use at Crewe with a pair of /1s? I thought one of the issues with going 8-car was that the bay wasn't long enough.
  7. crehld
    crehld Established Member Senior Fares Advisor
    1,981
    1 Nov 2014
    Between Crewe & Hellifield
    Platform 1.
  8. Bletchleyite
    26,611
    Cheers.
  9. Aeion
    Aeion Member
    48
    26 Mar 2015
    They have been going from platform 5 for the last several weeks
  10. sd0733
    sd0733 Member
    929
    7 Nov 2012
    Yes 5 is the default but I've also taken it off 11 and 8. The evening arrivals though do tend to always arrive into platform 1.
  11. 185143
    2,753
    3 Mar 2013
    It was dud 350119
  12. crehld
    1,981
    1 Nov 2014
    Yes I was initially referring to the evening arrivals :oops:
Thread Status:
Share This Page
