D365
- Joined
- 29 Jun 2012
- Messages
- 11,460
Incorrect. What about Wolverhampton to Shrewsbury....
As has been elaborated on, not long ago.
Couldn't they move the Aylesbury via Harrow on the Hill services to London Underground operation and the Aylesbury via High Wycombe services be operated by AC/battery EMUs, electrify Snow Hill to Shrub Hill/Foregate Street along with Bromsgrove to Great Malvern then transfer the Hereford services from Worcester to GW franchise? No need for any 17x traction in London Midland then and solves the Chiltern problem.
Allocate Class 91s and MK4s to Chiltern for Birmingham to London, meaning the 16x traction can leave for Up North
On the other hand, I dread to think how much it would be to electrify the Ledbury Tunnel - that's why I suggested terminated LM services at GMV as the ex BHM services could interwork with BSW services via WOF.
That shouldn't be too much of a problem seeing as it's partially electrified towards the Oxley TRSMD. All it'll probably take is for the single wire OHLE to be changed to the standard type and then extended further, taking into account the obvious associated work required. Given that, I reckon there is a good BCR that would build a good case for electrifying the section, more so now that direct services to London have been resurrected.
Indeed.
Thinking about this in the past in the context of Crossrail extensions, I concluded that you could justify OOC to High Wycombe as a phase 1, to Oxford/EWR and Aylesbury/EWR via HW as a phase 2, and Bicester to King's Sutton/Banbury + Northolt to Marylebone as a phase 3. That sidesteps the thorny issue of interworking with the Met for as long as possible.
Once you have the southern section covered by the above, the central section covered by the electric spine, then it's just the northern section Leamington to Moor Street you need to think about before the whole Chiltern mainline operation could go electric.
Birmingham-Worcester and Hereford electrification is definitely being looked at as part of a broader programme to eliminate as much diesel working in the West Midlands region as possible
If this does happen, it's unlikely to start before CP7 due to the large volume of work in the already announced electrification schemes.
One could simply provide Chiltern with Dual Voltage stock and bond the neggy to running rails where required. Changeover from DC to AC at Wembley Central ish and on the move north of Ammersham.
Alternatively, don't Bombardier Movias (S stock) have a pretty standard traction package. Could you modify those to run off OHLE instead as a cheaper option than new build dual-voltage stock.
...wouldn't you have to convert north of HotH to bonded 3rd rail (a-la DC lines, Richmond branch, etc al.) to be able to run mainline dual voltage trains anyway? Seems like a lot of work for the just 2tph or so I'm fairly certain are the only TfL use of them (and during the peaks only!). Given the costs of conversion to 3rd rail and the lifetime maintenance costs on the dual-voltage Chiltern rolling stock needing the DC as well as AC equipment - if you're going to spend that much you really may as well just put in OHLE and have cheaper (and more standardised) NR rolling stock and use those paths to bolster elsewhere. :/
Conversion from 4th to 3rd rail, provided the section gaps are available is as simple as moving round some bleed resistors and bonding out the neggy rail, with a few other things as well. But it would merely need the areas that want centre bonding isolating and bonding through. The heavy equipment like the transformer-rectifiers, switchgear and other associated cabling will remain unchanged.
I really don't get why you'd think it's so much work.
Compared with having 25kV OHLE and 750V DC in the same area, centre bonding is a cakewalk.
The line is ripe for more growth if the infrastructure was there to provide it, but TfL clearly have no interest and Chiltern have little say in the matter as it's TfL's infrastructure.
Is it? Where's the market? You know as well as I do that outer Metroland is an area of very high car ownership and the existing rail market is prinicpally commuter-based. I just don't see where the latent demand you imply will come from.
THC
I was under the impression that the electric service to Bromsgrove would be an extension of the Cross City line from Longbridge. If that is the case then terminating trains from Hereford at Bromsgrove instead of New Street would extend journey times considerably
There is no reason why the section from Harrow to Amersham could not be dual electrified as long as the Met lines retain their isolated 4th rail electrification system. It is the return voltage drop in the running rails in a 3rd rail DC system that prevents (or makes very difficult) dual electrification as the return voltage drop can drive a DC current through the transformer and cause saturation. However the isolated return path of the 4th rail system means no traction current flows in the running rails so there is no DC voltage drop in them to interfere with an AC system. Maybe more costly than a single system but solves the problem.
LUL 4th rail isn't fully isolated from the running rails...
Tfl don't agree with you though, they want it to the WCML as the alleviation to Euston and the Underground is more than you think. Crossrail is not a long distance service and Tfl didn't really want it to go as far as Reading regardless of it being an obvious place to go, so expecting it to Bicester and Oxford is not going to happen.
I agree that it would be a silly idea to have Hereford trains terminating at Bromsgrove - but the suggestion thought that with additional Cross City services to Bromsgrove, it would cause pathing problems with all the other services between Birmingham & Bromsgrove, and one solution might be to sacrifice most of the through services between Birmingham & Hereford. I am told that it is already difficult for Cross Country services to get a fast, unchecked run into Birmingham New Street from the Cheltenham/Bristol line.
Would a workaround be to extend the present Great Malvern via Stourbridge service to Hereford, and have a Great Malvern - Bromsgrove shuttle i.e. swapping the services around?
In peace
Adam
This seems very short-sighted given the distances Thameslink covers. Peterborough is quite a bit further than Oxford.
Thats wrong as i've seen the reports. It is the freight that gets stuffed. It is difficult with the Cross City as it is currently to get unchecked timetabled runs for XC, Bromsgrove doesnt break it. I would need to check the signalling diagrams too as I dont think the resignalling allows turnbacks towards Droitwich so the Herefords wouldnt necessarily be able to terminate anyway.
Ideally, as part of the Bromsgrove electrification the Down Goods should be extended from Cofton to Barnt Green and both it and the Up Goods upgraded and electrified.
Also, would it not make sense for all daytime Inter-City Cross Country trains to be routed via the Camp Hill line and reversed at New Street where necessary as this would ease congestion on the Cross City and potentially improve reliability of both Cross City and Cross Country services? Some evening workings could continue to run via Selly Oak to maintain route knowledge.
Not happening as part of Bromsgrove.
The 4th rail is fully insulated from ground and takes the full return current. Normally it is at a negative potential from ground around -150V. Traction equipment on trains is checked for isolation from ground and a train withdrawn if not. There is fault detection equipment on the supply system that would flag a warning if more than a few amps flowed in the running rails.
