LNER Azuma (Class 800/801)
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
The law in this country dosent accept that everyone can read. Nanny state.
K
I would argue that the “nanny state” does indeed accept that not everyone can read, because it’s a truth - not everyone can read English.
Also, it has apparently actually been demonstrated the the azumas do interfere with signalling systems whereas the existing trains don't - whatever the actual reason, the azumas are not compatible with the infrastructure, but older train are.
A point worth mentioning that. It’s also worth noting that the majority of electrification on the GWML is new, with newer signalling systems using axle counters (which are less prone to interference, on the whole - the faulty one at Moreton this time last year is an exception!), while the ECML is still mainly using track circuits tuned to an AC frequency out of the range of the 90s, 91s etc. using the route daily. Said circuits may not be tuned out of the range of the Azumas and their ilk.
spinba11
I was a Newark Northgate on Friday and saw a 800 with no cables attached on the upper rows, they were still there on the bottom row. It was the same all along the train.
800001
24 Oct 2015
Some carriages have 2, some 3 and some 4.
Wivenswold
24 Jul 2012
Essex
You left out the blind, partially or impaired sighted, they outnumber non-English speakers 20/1.
92002
27 Mar 2014
Clydebank
What seems to have happened is that the DfT has turned round to Hitachi and said 'we are not paying Network Rail to make the rail network compatible with your trains given that your competitors products don't cause these issues'.
Obviously this is at odds with what Network Rail are doing on the northern ECML, but I get the impression that the EMC problems aren't limited to the the northern ECML. It's just that the northern ECML EMC issues are much greater than anywhere else. That's my take on it anyway.
Another test run in the system for Wednesday, reputedly running on electric. From Doncaster to Inverness. If it takes in the New electrified area could run on old ECML, newish lines to Newbridge on the Bathgate line, then the new lines to Dunblane recently switched on..
So guess we shall see and hear of results at some point.
43096
23 Nov 2015
I’ll be impressed if it gets to Inverness on electric...
td97
26 Jul 2017
When was the last time they utilised OLE north of Doncaster (or is it York?)? I personally have never seen one running on the north ECML on electric.
This is the path for anyone interested: http://www.realtimetrains.co.uk/train/K97545/2018/12/05/advanced
An eventual 433:146 miles (basically 3:1) of electric:diesel running for London-Inverness is a remarkable improvement on the current 0:545 ratio.
Roger100
30 Dec 2017
Wingate
The last one I photographed running up here on electric was 801101 on 19th March 2018. Mind you I haven't really taken much notice since then, although all the 800 and 802 units I've photographed locally were running on diesel. This unit was running north near Bradbury, about half way between Darlington and Durham.
43096
23 Nov 2015
Left Doncaster with pans down and diesel engines running (let’s call them what they are - not this “GU” nonsense).
92002
27 Mar 2014
Clydebank
Arrived Edinburgh 5E at 1335, with both pantographs raised. Departed 2E after changing to diesel. 801202 leading 801201.
43096
23 Nov 2015
Must have been Berwick or somewhere they put the pans up - passed Newcastle on diesel. Units are 800202/201 I suspect...
FQTV
27 Apr 2012
Pans were down and running on diesel through Durham at 10:45.
