LNER Azuma (Class 800/801)
Max
8 Jun 2005
Cardiff
Took an inaugural Azuma ride yesterday on 1718 KGX-HUL. First impressions generally very positive: carriages bright and airy; lots of legroom in the airline seats; good provision of toilets throughout; and very quiet in both electric and diesel modes (the switch to diesel between Donny and Selby was barely noticeable). One thing I really noticed was that the dwell times at station were impressively short, particularly at places like Selby and Brough where previously you would be standing for 3-4 mins while the guard walked the full length of the platform checking the doors. It definitely helped us to recover a few minutes after a slightly late departure from the Cross and an additional call at Retford.
However, I'm afraid I do have to agree with the negative reviews of the seats. I don't find the angle/pitch too bad at all, but they really are very hard and the material is scratchy on your legs. I'm really not convinced that they couldn't have improved the quantity of padding in the seats, which clearly have been spec'd based on cost above comfort. Also not overly impressed with the PIS; we called additionally at Retford and the guard said he was unable to change the calling pattern on the PIS announcements, causing some confusion for passengers. Is it the case that only predefined calling patterns based on services can be selected?
Meerkat
14 Jul 2018
The orange line around the roof.....it’s an electrification warning right?
Why does it go over the headlight rather than under it, are there any rules on its height?
Sirgerbil
19 Sep 2012
It's called a "cant" line, it designates the safe working area when the OHE is live. Anything above the cant line is considered dangerous.
Kite159
27 Jan 2014
West of Andover
One small thing I noticed in coach K of 800102 is on the doors separating first from standard it has "Standard" facing standard. Wouldn't it be better to have "First" pointing towards standard to stop people thinking more standard class seats are available?
(Not sure if you can see it)
(Avoid K67 & K72 as those seats are against a pillar)
hexagon789
2 Sep 2016
It would. Surely having "First Class" on the Standard Class side and perhaps "Standard Class" on the First Class side would be logical?
43055
8 Mar 2018
The line is yellow around the headlight rather than orange. Looking at other images the line is not present on the standard class end so I would assume the yellow line is it show that it is the first class end of the train.
Sprinter153
12 Aug 2014
In the TGS
No, in fact it’s very easy to modify the calling pattern if needed with just a few taps, but I’ve found on GWR that a lot of the guards either can’t or won’t use the TMS correctly which is quite frustrating as it has quite a lot of useful functionality.
This is despite it being included on the Guards course and Hitachi also provide a TMS Simulator Android app for training.
westv
29 Mar 2013
I did mention the hard seats in a tweet to LNER on Friday. Unsurprisingly it was never replied to
Kite159
27 Jan 2014
West of Andover
It would be, certainly would reduce the number of standard class passengers walking into first class by mistake. I can't recall if the doors on the GWR 5 coach versions are similar.
Caught the 16:16 service this afternoon from Leeds, other than it being red inside it felt the same as a GWR unit. Good acceleration (I wonder if Leeds - London in 2 hours will be possible), although it did crash a bit over pointwork but a much better ride than a MK4 coach
hexagon789
2 Sep 2016
Most companies have signs stating "First Class" on the Standard Class side.
I've read very mixed reports on GWR IET ride-quality, interesting to see if they will be better than a Mk4.
TheBigD
19 Nov 2008
Leeds-London journey time is planned to be reduced to just 2hours once all the timetable/infrastructure improvents happen in the coming years. Number of stops will be removed as well.
Unless its changed the service will be half hourly, 1 per hour calling at Wakefield and Peterborough, and 1per hour calling at Wakefield and Doncaster, both taking just 2 hours. An extra service every 2 hours (from Harrogate) will call at Doncaster, Retford, Newark, Grantham and Stevenage.
Shepley
6 Oct 2018
The 07.00 from Leeds Monday - Friday arrives KX at 08.59 so the gain with the new rolling stock is the time of an extra stop (including braking / acceleration).
WYSH
18 Aug 2017
I thought the Harrogate service was to also stop at Wakefield has this changed
TheBigD
19 Nov 2008
December sees 6 of the current London-Leeds services extended to/from Harrogate. This is a temporary plan until all the timetable/infrastructure improvements take place, probably 2021 or later.
57Tonic
20 Aug 2016
This may have been done before but looking at the Rosyth picture above,
I thought how much nicer this livery would look on the GWR with green replacing the red instead of the rather bland all over green. Photoshopers its over to you,
modernrail
26 Jul 2015
It seems a bit stupid to add stops to the longer route. Surely you want less not more stops on the Harrogate route. I would have thought something like Leeds, Wakefield, Doncaster, Peterbrough would be the ideal pattern for those services.
VT 390
7 Dec 2018
What will replace Grantham and Stevenage services in the alternate hour to when the Harrogate service operates?
CaptainHaddock
10 Feb 2011
What about those of us travelling from Doncaster to Peterborough?
westv
29 Mar 2013
A two hour journey is a pipe dream for us in Hull. Once everything is sorted the direct LNER journey will still be 40 minutes longer than that.
Meerkat
14 Jul 2018
Good spot!! To be pedantic shouldn’t the orange line still continue below the headlight though?
waytogo
20 Jul 2011
No the guard was correct, it isn’t possible to add stops in, only take out. The stops are predefined based on the head code of the train.
