LNWR / WMT 350 on Tyseley this morning.
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
I’ve just past Tyseley on my way into work this morning and there appears to be at least 2 cars from a LM liveried 350 down by the Loco Works side. Out of interest, Does anybody know which 350 it is and what it is doing down there?
Thanks.
nat67
23 Apr 2014
Warwickshire
I think it is one of them that had an accident either the Watford Jn incident involving 350264 and 350233 which is more likely to be the one in Tyseley.
sd0733
7 Nov 2012
264 and 233 are both in service and have been for some months so definitely not either of those.
246 is more likely.
PHILIPE
14 Nov 2011
Caerphilly
A similar question has been asked before and it was stated they were taken there to use the wheel lathe. Don't know if this was the case this time.
sufian123
1 May 2017
246 is more likely.
Don’t forget 350233 and 350264 are mix match sets. They are not in their original forms.350233 has a carriage from 64 and vice versa. I think a carriage from 246 as well. Could be 2 carriages from 233 or 264. Not sure.
sd0733
7 Nov 2012
True forgot about that! I think all of 233 is back...3 of its own and one in 264. 264 has the other coach I think. So it's one coach of 264 and 3 of 246 still out of use.
sufian123
1 May 2017
That’s interesting. Could be 350264 Damaged parts at tyseley then. 246 carriages are at repair.
sd0733
7 Nov 2012
Depends what coaches they are, if it's centre cars Its almost certain to be the 2 centre cars from 246 as they are the only ones not in use and wouldn't have sustained much if any damage whereas the DM vehicles from 264 and 246 would have.
sufian123
1 May 2017
That’s interesting. I’ll see if I can make a trip down. You can walk outside the depot. Pass by car. You can see it though the gates. I’ll see if I can get a closer look.
fgwrich
15 Apr 2009
I believe they were centre vehicles - unfortunately I couldn't see them as I was on a passing Voyager I'm afraid, but you should be able to see them from the roadside.
Defiance149
30 Dec 2013
Centre cars 65246 and 67546 from 350246 were last heard of at Tyseley. 61446 last heard of in Germany and 61564 (350264) at Northampton.
