Loco's Rescuing Multiple Units - Maximum Speed
Dai Corner
20 Jul 2015
The other day 37 418 was used to rescue a failed Cl769 DEMU on the Rhymney Valley line. It took several hours to clear the line as the maximum permitted speed was 5mph. I understand this is because the loco is unable to apply the unit's brakes.
Now, when it was new nearly 60 years ago the loco would probably have hauled unfitted freights many times heavier than a 769. Not very fast (30mph?) but faster than 5mph.
Why the 5mph restriction now?
PHILIPE
14 Nov 2011
Caerphilly
Health and Safety have come along way since those days. In the days of yore an unfitted freight sometimes had a number of empty vacuum fitted vehicles known as a vacuum head next to the loco and to provide Brake Force
craigybagel
25 Oct 2012
You don't get to our current levels of safety through keeping going the practices of the past. I'd take the odd 5mph drag over the high accident and fatality rate we had back then any day.
O L Leigh
20 Jan 2006
In the cab with the paper
Primarily because of the lack of brake continuity through the train, but remember also that modern MUs have no buffing gear. A collision with the loco within the confines of the slack in the coupler due to a sudden brake application from 30mph could cause damage to both loco and MU. Having seen a Tightlock fitted EMU rescued by a conventional loco it's done by passing the end of the loco's shackle through the slot in the Tightlock's jaw and dropping the "mushroom" adapter through a vertical hole that runs through the end of the jaw to secure the shackle link in place. However, as the MU has no buffers the shackle can't be wound in to reduce movement meaning that there can be a fair bit of slack between loco and unit.
It's also worth pointing out that an unfitted freight would have had a brake van with the freight guard at the rear of the train which a loco + MU rescue formation would lack. Granted there would be a person on the MU to apply the parking brake in the event that it was needed, but the amount of brakeforce that provides can be very low given that it's only really intended to prevent the MU wandering off on it's own when it's own air supply is exhausted. I suspect that, if the Cl319 on which the somewhat heavier Cl769 is based on is similarly provisioned to the Cl317s I used to sign, the parking brake only applies on the lead bogies on the driving trailers and, if applied by operating the PBIC in the cab rather than exhausting the main air supply it would only apply on the bogie at the end of the train and not both. I was told when I was being trained that the spring operated parking brake is equivalent to a Step 1 brake application. Given that it would only be operating on 1 out of 8 bogies it would mean a 1/8th Step 1 brake equivalent which really isn't very much at all. It would take quite a while for a brake application that light to stop an MU from any appreciable speed.
jamieP
27 Feb 2012
Just to point out units these days are rescued using a coupling adapter and not by using the shackle.
