London branches on travelcard
route101
16 May 2010
Looking at doing some of the branches within the travelcard area in the South of London. Anyone done this before and effective way of doing it ?
Ianno87
3 May 2015
For starters, Epsom Downs and Tattenham Corner can be combined by walking from one to the other.
AM9
13 May 2014
St Albans
Caterham can be visited, then travel back to Whyteleafe, walk to Upper Warlingham, and board a train for different scenery on the way back to East Croydon.
ashworth
10 Sep 2008
Notts
If you don’t know the area I suggest arrive at Epsom Downs and walk to Tattenham Corner. I did it the other way around and it took me ages to find Epsom Downs. It’s really hidden away through a fairly upmarket housing development. Very pleasant area around the race course for walking.
route101
16 May 2010
Will look into that .
route101
16 May 2010
Wont have a car , other branches i will look at will be the hampton court and other SW branches and Hayes . The Southeastern network looks a little confusing , will need to figure that out .
Staying near wembley , will do the Watford Overground and may as well do the St albans abbey branch.
route101
16 May 2010
Bromley North is an easy walk down the high street to Bromley South (10-15 mins) or you can hop on a 119 bus to Hayes and cover that line too.
The 353 from Hayes to Orpington could also be useful to you.
Thanks , will look at the map .
25 Apr 2017
Mainly SE Asia, occasionally Central Belt
Personally did the 314 bus from Hayes to New Addington instead, to clear the Hayes NR branch and the New Addington Tram branch instead
Walked from Tattenham Corner to Epsom Downs cuz I just picked whichever train came first - it's not too bad if you use Google Maps in my opinion! Walked down Old London Road, Fir Tree Road, Ruden Way, and then down a small alley (marked on Google Maps, but don't recall any obvious signs when I was there!) and Bunbury Way - crossing the roads were the most intimidating part I think!
Took the 71 bus from Chessington South to Surbiton for the train to Hampton Court to knock both branches out in one day, you could probably further chain that up to Hampton via the 111/216
route101
16 May 2010
Might be a shout doing the tram . Only down Wimbledon to Croydon . How long did the walk take ?
AM9
13 May 2014
St Albans
With a standard zones 1-6 Travelcard, you can only go as far north as Hatch End. Watford is in zone 9 and the Abbey Line is totally outside the tfl zones.
As, if starting from Wembley, why not get a train from Wembley Stadium to South Ruislip, then on the Central Li e back to Greenford, then take the GWR branch to West Ealing, change there onto a class 345 to Ealing Broadway. A District line train will take you to Acton Town where you can change onto a Piccadilly to Hounslow Central for a short bus ride to Heath Road which is a short walk from Hounslow SWR station. From there you can go either way around the Hounslow loop back to Clapham Junction, then catch a train to Hampton Court. Then, break for lunch. :)
route101
16 May 2010
Yes im aware , happy to buy a ticket for the abbey line.
route101
16 May 2010
Hayes , Chessington South , Hampton Court , Epsom Downs , Caterham , Tattenham or on the hit list .
30907
In that case the 314+tram suggestion above will take you from Hayes to East Croydon (for Cat/Tat).
Alternatively, back to Elmers End and tram from there - quicker, but less tram (and less interesting tram route IMO).
mrcheek
11 Sep 2007
If you go to Tattenham Corner, be sure to turn left as you come out of the station, a walk across a field of 50 yards, and then you have one of the greatest views in Britain, a hill overlooking the racecourse, with views beyond across the downs
route101
16 May 2010
Duly noted .
Is it DOO?
Nope.
I've always done TAT to EPD; its downhill!
As for Caterham, you could get a bus to another line, to avoid doubling back. But yes as said above the Upper Warlingham walk is easy (it's downhill if you walk from Upper Warlingham - as the name suggests!)
route101
16 May 2010
Yepi did , there was a town in the distance with office towers , cant quite work it out . Woking or Dorking.
route101
16 May 2010
Touched out at Corner at 1801 and touched in at Downs at 1826, so 25 minutes!
I just made my train at Epsom down with a few minutes to spare , went down back streets and two back alleys . That station is well hidden in a late 80s (I think ) housing estate.
route101
16 May 2010
Done Hampton Court , Caterham , Tattenham corner , Epsom Downs , line to Lewisham , Hayes ,Watford to Euston DC , Line out to Winsdor via Staines , Windsor to Slough , Hounslow Loop. Chessington was closed .
Them third rail lines in South London are hard to keep track off . The SE network in particular .
