I'm visiting Amsterdam for a conference in June, and am planning on going by train and ferry to avoid having to contend with Schiphol and the faff of flying.
This is during the blockade of the Hoek van Holland line - so the usual route is a replacement bus to Schiedam and pick up the train to Rotterdam, then to Amsterdam. However, as it'll be summer, and given that the Netherlands is a sensible country which sees a bicycle as a means of transport rather than a piece of sports equipment, I was planning on taking my bike with me, and then cycling to the nearest station to reach Amsterdam.
I think the closest (open) station to Hoek van Holland by road is in Den Haag - at which point I might as well just go to Den Haag Centraal and take a train to Amsterdam from there. It's about 21km, which should be easy enough (my commute to work every day is 10km.)
Does anyone have much experience with taking a bike on the Stena Line Harwich-Hoek sailings? Any horror stories?
And as for the train from Den Haag to Amsterdam: how reliable are the Intercity services via Leiden? In the return direction (on a Wednesday), I need to be at the Hoek terminal by 21:15 (when check-in closes.) The first off-peak departure from Amsterdam at 18:34 gets into Den Haag at 19:26, with a change at Leiden. This seems like it'd be a little tight. I can cycle quickly if needs be, but an hour and forty-nine minutes to go 21km could be cutting it fine - especially if a train gets cancelled or I get a puncture.
Any views on whether I should travel before the evening peak instead? What are the rules on taking a bike on the edge of the peak hours - does the journey have to be completed before 1600, or does it just have to start before 1600?
Thanks in advance for your opinions/expertise/derision!
