As far as I can see from brfares.com, travel from London to Reading at the off-peak contactless rate has no evening restrictions:
https://www.brfares.com/!faredetail?orig=1072&dest=RDG&tkt=POC
https://www.brfares.com/!faredetail?orig=1072&dest=RDG&rte=801&tkt=POC
And Reading to London does or doesn't depending whether you look at Any Permitted or Via Slough:
https://www.brfares.com/!faredetail?orig=RDG&dest=1072&tkt=POC
https://www.brfares.com/!faredetail?orig=RDG&dest=1072&rte=801&tkt=POC
even though as I understand it, via Slough is the only route on which contactless can be used.
Am I correct in thinking that you can therefore use contactless to travel for £13 each way on any train from Paddington to Reading or vice versa at any time outside the morning peak, or am I missing something?
(I'm assuming this is too high-profile and mainstream to be a loophole whose existence is endangered by mentioning it. Forum staff please delete the thread if I'm wrong about that).
