London Terminals - has something changed?
Discussion in 'Fares Advice & Policy' started by mailman, 5 Sep 2018.
  1. PeterC
    PeterC Established Member
    1,906
    29 Sep 2014
    As part of the rebuilding the sub surface and tube stations were connected behind the barriers.
  2. Haywain
    Haywain Established Member
    3,552
    3 Feb 2013
    From the 'outside' it actually looks the opposite with two gatelines serving the deep tube lines and one serving the sub-surface lines.
    They had been connected behind the barrier lines for a very long time before the rebuilding.
  3. Hadders
    Hadders Established Member
    6,062
    27 Apr 2011
    You've fallen for the signage that sends you via the 'tourist route'.
  4. OwenB
    OwenB Member
    297
    8 Mar 2018
    To be honest, I only ever take the Northern line. Interesting to know though!
  5. greyman42
    greyman42 On Moderation
    1,004
    14 Aug 2017
    It is the other way around. 1 set of gates serving Metropolitan etc, 2 sets of gates serving Piccadilly etc. You cannot get from Metropolitan to Piccadilly without passing through a set of gates.
  6. Hadders
    6,062
    27 Apr 2011
    You most certainly can get from the Met to the Piccadilly without passing through a set of gates. In fact once through any set of gates you can get to any line.
  7. westv
    westv Established Member
    1,883
    29 Mar 2013
    Unless the infamous one way system is in operation!
  8. causton
    causton Established Member
    5,268
    4 Aug 2010
    Enter a crudely drawn map:
  9. Hadders
    6,062
    27 Apr 2011
    Good map. It really does demonstrate how long the 'tourist route' to the Victoria Line is, especially when you consider the signs for the Victoria, Piccadilly and Northern Lines adjacent to the Tube Ticket Hall direct you to the Northern Ticket Hall.
  10. talldave
    talldave Established Member
    1,432
    24 Jan 2013
    IIRC there's one point in the subterranean tourist attraction where the Victoria line is signed in both directions!
Share This Page
