London to Heathrow Terminal 5
Discussion in 'Fares Advice & Policy' started by Cbob, 8 Oct 2019.
  1. Cbob
    Cbob New Member
    4
    4 Nov 2017
    I am thinking of travelling on the TfL Rail service from London to Heathrow, using an Oyster Card with Annual Gold Card discount. My flight is from Terminal 5. I believe I can use the Heathrow Express to get to Terminal 5 since this is not served by TfL Rail, but how can I make use of this and avoid getting charged the Heathrow Express rate when I touch out in Terminal 5?
    Rail Forums
  3. Cbob
    Cbob New Member
    4
    4 Nov 2017
    I meant use the 'free transfer' provision within Heathrow to get to Terminal 5
  4. paddington
    paddington Member
    820
    19 Feb 2013
    As long as you touch in at the TfL rail gateline at Paddington, rather than the Heathrow Express one, you will be charged the TfL rail fare.
  5. Cbob
    Cbob New Member
    4
    4 Nov 2017
    Great, thanks for the quick response!
  6. Kite159
    Kite159 Veteran Member
    13,221
    27 Jan 2014
    West of Andover
    Sorry for hijacking the thread, but a completely silly theoretical question. What fare would be charged if someone was to tap in at the HEX platforms at Paddington, board a HEX to Heathrow, remain within the station, and return to say Ealing Broadway on a TfL Rail service to touch out at Ealing Broadway?
    (That is assuming the HEX services only have ticket checks in business class, and the card isn't checked in standard class)
  7. paddington
    paddington Member
    820
    19 Feb 2013
    My guess would be a Heathrow Express single fare depending on the time touched in plus a Z1-6 maximum fare / incomplete journey ending at Ealing Broadway
    I can think of a way to find out that won't cost me anything (apart from some blacklisted cards...) but I don't really care to know the answer.
  8. MikeWh
    MikeWh Established Member Senior Fares Advisor
    5,715
    15 Jun 2010
    Crayford
    I think that's unlikely to be honest, unless the maximum journey time between Paddington and Ealing Broadway has been exceeded. If the same scenario exists as per Gatwick Express gates at Victoria then it will charge the normal fare for Paddington to Ealing Broadway.
    Just checking the card wouldn't make any difference, especially on the Hex. It would show as touched in (if Oyster) or valid to travel (if contactless).
  9. daveshah
    daveshah Member
    41
    1 Sep 2018
    In the case of contactless, it would also put an "inspection" marker on the card in the backend. But this would only be used to charge a maximum fare if not touched in; not to determine the route of travel for fare calculation.
  10. matt_world2004
    matt_world2004 Established Member
    2,252
    5 Nov 2014
    I don't think you can get to the TfL rail platforms from the hex platforms without touching out. But say hypothetically you just wanted to ride on the hex for the experiance. You could touch in with an oyster card at terminal 5 get on the train to Paddington and make a return journey from Paddington to Heathrow Central for £0 providing you touched out at Heathrow central
  11. James Wake
    James Wake Member
    889
    30 Aug 2013
    Would that work with contactless too? I might have to give that a try one time if I get a chance
  12. Kite159
    13,221
    27 Jan 2014
    West of Andover
    It was a hypothetical journey, at Heathrow Central (Terminal 2 & 3) it is an island platform. There is probably something in the backend system as a "just in case" a stopper goes from P6 or P7 in times of service issues [i.e. a train has broken down blocking access to some of the other platforms]
    Although Heathrow T5 - Paddington - Heathrow Central (- Heathrow T4) sounds like it would work, but who is willing to give it a try?
  13. matt_world2004
    2,252
    5 Nov 2014
    Should do. The only thing that I think could go wrong is that it exceeds the max journey times although it should take about 40 minutes on a round trip ,which I imagine might be less than doing an terminal 4-5 journey when the inter-terminal transfer service is down.
  14. Snow1964
    Snow1964 Member
    13
    Kingston upon Thames
    If you exceed max journey time would depend on how it is set, if you touched in, train was about to go, got to Heathrow Island platform, and a train back to Ealing was just about to go, then you might get there quicker than if you touched in having just missed a train, next direct train to Ealing was few minutes late departing etc.
    In both cases could exit about 40 minutes later (maybe more if you stopped at station toilet etc) which makes setting the maximum journey time quite difficult.
    There are actually quite a lot of places within the oyster network where getting a fast train beyond, then going back station or 2 is quicker than waiting for next direct stopping train which may leave later (but pay-as-you-go would never pick up the extra section if it is retraced before touching out). If this extra is moral is another debate, but is a a consequence of having zones that can be reached faster.
  15. MikeWh
    5,715
    15 Jun 2010
    Crayford
    They are the same platforms at terminals 2/3.
    The Oyster conditions of carriage simply state that you must touch in at the beginning of your journey and out at the end. As long as you stay within the Oyster area you cannot be off-route. And the absolute minimum maximum journey time is 70 minutes.
  16. matt_world2004
    2,252
    5 Nov 2014
    But not at Paddington.
  17. MikeWh
    5,715
    15 Jun 2010
    Crayford
    Unless I've misread the OP for this discussion the change is happening at Heathrow.
Share This Page
