London to Manchester any permitted route,
cambsy
6 Oct 2011
Is the London Terminals to Manchester off peak return, still valid via Sheffield? Just have not used it for a while, so wanted check can still use Sheffield to St Pancras, and what are the other valid routes? Have looked at the routing guide,, but its so long winded and confusing, its not clear where valid via, as the codes are not usual 3 letter codes used in timetables etc. seem to have to use maps which long winded, is there easy way to use routing guide? Thanks
trebor79
8 Mar 2018
Easiest way is to put it into a journey planner, specifying via Sheffield and see if it offers you that ticket.
The Routeing Guide isn't really intended for consumption by the average passenger; your best bet is to put your journey query into a booking site to see if you can generate an itinerary.
London to Manchester is valid via Chesterfield on map 'PR'
