Longest Wagon in the UK?
popeter45
7 Dec 2019
london
reading the specs for one of the proposed HS2 rolling socks the Velaro Novo its car length is really long at 28.75m and that got me thinking what is the longest carriage/wagon in common use in the UK and where can they go?
hexagon789
2 Sep 2016
Probably the 80x IET trains with their nominal 26m long cars, Mk3s are only nominally 23m by comparison
hwl
5 Feb 2012
reading the specs for one of the proposed HS2 rolling stocks the Velaro Novo its car length is really long at 28.75m and that got me thinking what is the longest carriage/wagon in common use in the UK and where can they go?
A requirement of HS2 is 25.0m intermediate vehicles. The Siemens bid is based on Velaro Turkey (25.0m) not Velaro Novo...
The longest wagon by your criteria is the MOD's KUA flask wagon at 24.7m
Longest carriage IET at just smidge under 26m
themiller
4 Dec 2011
Cumbria, UK
There's a 12-axle nuclear flask wagon that travels between Sellafield and Thurso where the rail bogies are removed and road bogies attached for the last few miles to Dounreay. It was made by Head Wrightson. I've seen it a few times but can't find it by a web search.
hexagon789
2 Sep 2016
Do you know roughly when it was built? A quick Google turned up a 12-axle wagon but built in the 1950s, so I took it not to be the right one
DarloRich
Fenny Stratford
Are you sure? That sounds very intresting
themiller
4 Dec 2011
Cumbria, UK
That sounds about right. Last time I saw it the colour scheme was very light blue and white. It has a cast plate in the centre of the wagon with the builders name. The flask is carried upright rather than on its side.
themiller
4 Dec 2011
Cumbria, UK
If you include industrial internal wagons, you'd have to go a long way to get a bigger wagon than the molten-slag torpedo wagons which, if the brain cells are still working, weighed in at something like 250 - 350 tons. Many years ago I saw a couple underway on Teesside on the British Steel internal system.
furnessvale
14 Jul 2015
There was a time that such wagons made regular trips on BR metals so, unless we are restricted to present day operations, they can also be counted.
ps. Its wasn't molten slag they carried but liquid metal (not sure if iron or steel).
themiller
4 Dec 2011
Cumbria, UK
When I saw them they were on their way towards where the slag was tipped leaving the steelworks behind them. I suppose they could have been carrying some ‘out of spec’ steel.
alexl92
12 Oct 2014
How long are the Drax biomass wagons? I thought they were about as big as could be used on UK loading gauge but they may not be that long - can't imagine them being 25m?
James James
29 Jan 2018
How long is the Eurotunnel "Le Shuttle" "Club Car"? Looks like a conventional continental carriage, which would suggest a length of 26.4m - but it's nigh on impossible to find much data on it, nevermind photos (because at least there's a chance the length is marked on the side).
Very limited range :D - the tunnel, and loading areas, I suppose.
themiller
4 Dec 2011
Cumbria, UK
25720 overall length. 25300 over body length. 19000 bogie centres. 2845 width. Reference: Channel Tunnel Trains. Peter Semmens and Yves Machefert-Tassin. ISBN 1 872009 33 6. Eurotunnel 1994.
Shimbleshanks
2 Jan 2012
Purley
Probably long gone now but in the early 1970s I remember seeing a pic of a boiler-carrying wagon in a mag, in the days when the railways still carried abnormal loads. From memory it was designated 'Boiler VB'
Dunfanaghy Rd
16 Sep 2019
Alton, Hants
WIAs are pretty long, albeit articulated in five sections. https://ukrailwaypics.smugmug.com/UKRailRollingstock/W-Tops-codes/WIA/
A WIA (WIA-A, WIE789) measures 66.365 m (218 ft). The five articulated sections form one vehicle - one painted number. I suspect that the various IEP-thingies, while a lot longer, are composed of several separate vehicles.
Some years ago there were the Cartic-4 sets belonging to MAT and Silcock & Collings. They were numbered as 4 separate vehicle, but some were then renumbered for International service whereupon they carried one number for the set (WIA-B, WIE823). Long gone now, thank goodness.
Pat
wallan
27 May 2020
Bedworth
You may find the wagon is at Locomotion in Shildon
James James
29 Jan 2018
Thanks, that takes that one out of the race.
If articulated units (e.g. jacobs bogies) were to count: the class 777 is 64.98m, which is beaten by the WIA already mentioned in this thread. But the class 755/4 at 80.7m trumps them both.
popeter45
7 Dec 2019
london
i was thinking more non-articulated units cause was thinking more of platform clearance but if going with articulated 373 half sets coach rakes must take the biscuit at 174.5m
