Loop services
mervyn72
23 Jul 2015
Thameslink's loop trains all terminate at Sutton and have a change of headcode, despite running to and from St Albans, so are technically two different services.
Is there reasoning behind this when the Cannon Street and Waterloo loop trains do not?
Peter Mugridge
8 Apr 2010
Epsom
I recall reading - probably on this forum - that it's something to do with preventing abuse of the direct trains rule for ticket validity.
The rumour I heard was that it was to thwart @RJ using the 'through trains' rule for ticket validity, though I don't know if that's actually the reason.
To be fair it probably makes sense to advertise these trains to Sutton, rather than St Albans to St Albans via Sutton and the use of 'false destinations' en route.
Some of the other loop services may be more problematical in this respect, in that there may not be an obvious place to change the service ID.
As things stand, you can travel from Clapham Junction to Earlsfield via Kingston for the same price as a direct train. But SWR probably aren't bothered; a paper ticket for that journey is not cheap, and it's an irrelevance for PAYG.
RJ
25 Jun 2005
Back office
I would suggest there's no truth in such a rumour at all. I'm pretty sure this arrangement on Thameslink predates me and I've never been on their radar for ticketing matters. Furthermore, I've always openly discouraged abuse/misinterpretation of the through train rule when people try to advocate break of journey on otherwise illegitimate routes.
They weren't always circular services anyway - for several years it was two interworked routes - Luton to Sutton and St Albans to Sutton.
Some things I will claim but not this one.
LA50041
20 Feb 2017
The Cannon st loop trains also change head code at either slade green or crayford
stut
25 Jun 2008
I think the Scottish loops have a similar split - the Cathcart Circle operates as a single headcode, but the Fife Circle seems to change over at Glenrothes with Thornton. Hamilton loop trains change over at Motherwell, but you can understand this, given the size of the loop relative to the rest of the line.
Romsey loop changes over in, well, Romsey.
IrishDave
30 Jun 2009
Brighton
I wonder if it might have to do with odd/even numbering - all Thameslink trains northbound through Blackfriars end with an even number, and all southbound with an odd number. So somewhere it has to change from odd to even so as not to confuse the signallers by having an odd headcode going north (or an even one going south).
In the London Bridge area for Southeastern, the split is odd numbers go to and from Cannon Street and even numbers go to and from Charing Cross, so keeping the same number all the way round the Cannon St-Cannon St loop is advantageous.
Then again, Waterloo is generally odds departing and evens arriving, except for the loop trains which are all odd numbers...!
800002
19 Jun 2019
Is there also something to think about with ARS and Trust getting into a muddle with the same headcode effectively double backing on itself?
I'm not sure of the 'loop duration' in the Waterloo /cannon st loops, ie the point it diverges and reconverges upon itself (thinking Lewisham in the case of the cannon St services) but could the Sutton loop be conciderably shorter this requiring a change in digits?
Springs Branch
7 Nov 2013
Merseyrail operate a line (the Wirral) where almost every train goes around a compact loop and back along the same line to its origin. They manage this without any change of headcode en route. The third and fourth digits are a simple count up in increments of 1 from the first train of the day.
The Wirral line is a self-contained, mostly isolated system, of course, unlike the Waterloo, Cathcart Circle etc examples mentioned.
