Lost property: tracking train via coach number?
cyakio
31 Dec 2020
uk
Seasons greetings to all and happy holidays , im glad i came across this forum as iv been trying for the past few days to locate a train which i left some luggage on i managed to take a picture of the front of the carriages 6 number and the 5 on the side but , for the life me of cant seem to work out or locate it on rail radar as it shows up eg JA**** or GV**** so slight confused
iv read the letters and numbers usually indicate the operator route etc but still confused and cant work it out all i know it was southeastern running victoria on the nunhead line
any help will be appreciated
py_megapixel
5 Nov 2018
Northern England
The set of 6 numbers on the front of the train are called the TOPS number. It is a unique identifier for that particular unit (for these purposes, you can think of a unit as just a set of carriages which are permanently coupled together).
The set of 5 numbers on the side of each carriage is a coach number, and is an identifier for that particular carriage.
It would help if you could inform us what the 5 digit number from the side of the carriage and the 6 digit from the front of the train were. It would also help if you can remember how many carriages the train was formed of, as we can then work out (if needed) whether the train was formed of multiple units coupled together.
But all of this is really only going to have a point if you are interested in the operational details of the railway. If you don't care about all of this, and all you want to do is find your luggage, then just phone Southeastern and tell them as many details as you can. More than likely your luggage isn't still on the train anyway and is in a lost property office somewhere.
StephenHunter
22 Jul 2017
If you have the number in question, you can contact Southeastern directly as they might have found your luggage.
cyakio
31 Dec 2020
uk
thanks
o
But all of this is really only going to have a point if you are interested in the perational details of the railway. If you don't care about all of this, and all you want to do is find your luggage, then just phone Southeastern and tell them as many details as you can. More than likely your luggage isn't still on the train anyway and is in a lost property office what you explained to me
this is exactly the info i was looking for and interested Thank you very much the train in question had 376032 on the front im trying locate the coach number i jotted down , it was 8 carriages
py_megapixel
5 Nov 2018
Northern England
I think you might have misremembered some of those details? The first 3 digits of the TOPS number (the number on the front) indicate what class the unit is - it's roughly the equivalent of say a model of car, but for trains. So the train you were travelling on was a Class 376.
Most units can either operate on their own, or with more than one of the same class coupled together ("in multiple"). But because class 376s have 5 coaches, it couldn't have been an 8 car train, because one on it's own would have been 5 coaches, and two in multiple would have been 10 coaches.
Here's a photo of a 376. Did your train look something like this? (Photo by Hugh Llewelyn under the Creative Commons BY-SA 2.0 license):
I'm happy to answer any further questions and continue explaining this, but I should warn you before you proceed further that this information is very unlikely to help you find your luggage - as others have stated, it's probably been removed from the unit in question by now anyway.
cyakio
31 Dec 2020
uk
thank you again my item was handed in i have to go pick it up at cannon st at some time , that was the train indeed i must of miscounted as i was rushing to try jot the number down
is there no way to track via the app radar or to find it in real time or does one need all the other details i was hoping there was a way by using the numbers on the front and using Traksy to see where it was
Thanks for you help - I have subscribed to your YouTube channel
21 Mar 2011
Sunny Scotland
No. There generally isn't.
Mojo
7 Aug 2005
Also probably wouldn’t help you much as most trains have a litter picker go through at the end of the line where any lost property would be tracked down.
ComUtoR
13 Dec 2013
One from 2019 with the service details and a pic of a 376 sitting at Victoria
Bottom of this thread with a mention and sighting of 376s at Vic.
The Op clearly mentions they were on a 376 into Victoria. I have no reason to doubt them. The 376 into Victoria was running daily and then COVID hit. I haven't been up to Vic since November but there was a 376 sitting in the wall sidings. I have no idea which service the Op was on and I also couldn't find anything non stop in the timetable. However; the sheer number of STP diagrams is making it difficult to track a specifc service. However, 376s can, and have, run into Vic from Lewisham. The Op may have been diverted.
If @cyakio is ammenable. Could they please upload the pic or the unit and/or let us know which service they were on.
