Lothian Buses and ECB Discussion
scosutsut
1 Jan 2019
scosutsut
From the BUS2020 document:
Does anyone know what the fleet mixture is like Euro wise these days with the XLBs? I'd have thought if another significant order was needed it wouldn't be too long until we heard about it.
Time between the initial XLB order annoucement and entry into service was ~9 months IIRC.
Pre Euro 5 your looking at the Irish plated ex Arriva and native 04/55 plate B7 singles and surviving native 55/56 plate B7 doubles I reckon.
Based on that all three fleets will need some form of replacements either directly or via cascade as the 2020 commitment is off fleet not just off city centre duties.
Jordan Adam
12 Sep 2017
Aberdeen
Pre Euro 5 your looking at surviving the Irish plated ex Arriva and native 04/55 plate B7 singles and surviving native 55/56 plate B7 doubles I reckon.
Unless they've had modifications already all the Pre-2009ish B7RLEs and B9TLs would need Ad-Blue fitted to get them up to Euro 5.
14 Dec 2018
Are Lothian having reliability problems with the fleet at the moment? I've noticed a lot of deckers on routes such as the 1, 20 and 24 recently, which normally use single-deckers, as well as the use of standard Lothian vehicles on the 300 (which should only use Skylink vehicles).
ScotRail158725
27 Nov 2018
only 15 singles at Central (1-10, 36-40) so theres not enough for the total PVRs of the 1, 6 & 24. the 20 & 63 usually get doubles anyway so nothing new there
Darklord8899
6 Jul 2018
...as well as the use of standard Lothian vehicles on the 300 (which should only use Skylink vehicles).
Being someone who uses the 300 for daily commute to/from work, at certain times of the day buses can be filled to the gunnels with commuters (rather than holidaymakers with luggage) so using standard vehicles makes sense and a welcome change!
cnjb8
26 Feb 2019
Skills Coaches seem to be having trouble with their former Lothian Tridents as by now their step-entrance deckers should have gone, some have but not all. I've seen two broken down in the past month.
Littles Travel also have a former Gemini still in Lothian livery. Its SN55 BMZ
ScotRail158725
27 Nov 2018
quite a lot of B7s sold, think i posted the full list 2 or 3 weeks ago
14 Dec 2018
Does anyone know of any Lothian passenger services or empty stock workings which use the City Bypass?
I've noticed on the tracker some buses heading eastbound at about 0400 in the mornings with a destination of "Edinburgh Airport", I presume these are from Longstone to Fort Kinnard for the 400? Why do these go out of the city and around the bypass rather than just directly to the Fort?
Thanks!
etetetetet
30 May 2019
Thanks!
I'm guessing speed? Maybe just to get them to the fort for the start of the day.
I know the training buses do occasionally go up the bypass, I saw one this morning use it
buslad1988
28 Dec 2018
Thanks!
There are lots of buses running empty in both directions along the city bypass before/after rush hours. It’s much quicker and makes more sense than running through the town - so they are heading directly there. Especially the 400... otherwise it might as well be in service.
Edirim
17 Nov 2016
Yes a lot of depot runs along the bypass.
Would be great if some were in service though perhaps if the council is serious about climate emergency it could work to get a hard shoulder bus lane for an orbital route...anyway tangent.
Services 2,3,4,21,25,30,33,44,48,49 & 400 off top of my head use bypass for some depot runs.
BobScott
22 Jul 2019
Anything running along the bypass in service would certainly not be profitable. These are only positioning journeys to get to the start point more quickly than running through the city.
ANWP Tom
31 May 2018
A few X buses return to Marine OOS via the Bypass in the evening. Less so some heading back to Central (At a guess central ex 15/31/37/47 and back into the city via London Road rather than through the centre and OOS from 12/49 plus Xs to Marine)
Empty 5 starter in the morning from Marine aswell
Central X44s also use the A1 back into town for completeness
14 Dec 2018
Thanks for all the replies, I hadn't realised so many buses used the bypass!
If the bypass is so busy at peak times though, would a service running from where everyone is coming from, going to where everyone is going to, not make sense? I'm never on the bypass so I don't know if it has a hard shoulder which could be turned into a bus lane? If so then that might be faster for a lot of people than waiting in traffic queues?
TheEastCoaster
26 Jun 2018
The one service I know that runs via the Bypass is horseburghs 40/X40 between Gilmerton and Hermiston! If LCB took over the tender for that service I wonder how well it would do
oldman
26 Nov 2013
The bypass has a hard shoulder for one section only. The problem would be that there is no single traffic flow to justify a bus service.
overthewater
16 Apr 2012
I think it would do rather well for lot of connections between south east of the city to Uni and sighthill.
Also its been over 10 years since the Southern orbital bus route has been on the books.
scotrail158713
30 Jan 2019
Dundee
Probably quite well as I’m sure the quality of buses would be better than some of the current ones
FlybeDash8Q400
26 Jun 2018
Edinburgh
If the congestion on the bypass wasn’t that bad the 40/X40 could have provided a link between two of the Park and Ride sites. Given this enquiry into Horsburgh it will be interesting to see if anything happens as a result of that
scosutsut
1 Jan 2019
scosutsut
Is there a view on whether the Bus 2020 plan allows for any exceptions, or will it be the end of the line for the open top Tridents and Scanias that are still owned? Will the promotional Dart also need to go?
On one hand you'd say yes but the preserved fleet is presumably exempt so surely that gives scope for a ruling on the others? Deemed non service buses and exempt? Follow BBTs example and sling compliant engines in them?
ScotRail158725
27 Nov 2018
open top scanias havent been used in almost 2 years so doubt they need to worry with them, not sure about the tridents but tbh they probably dont need to worry about stuff like that that come out every now and again
Lothiangem22
30 Jan 2019
120 buses are on order this year which should put bus 2020 plan right on track. Don’t have confirmation on vehicle types though it’s rumoured some movement from Longstone to Marine with at least some of the new batch going to Longstone including the replacement of the current B7 training fleet
CN04NRJ
28 Nov 2019
Are Longstone getting new singles?
