Scheiße Passiert.
Mann sprecht gute Deutsche!
Scheiße Passiert.
Ouch! Seeing 133 on fire hurts. I have travelled on that bus so much I would hate to see it scrapped Please Lothian, repair it and return it to service.I see one of those "Get There Greener" buses has went bang.
Denk ich auch soMann sprecht gute Deutsche!
I hope no one was injured in the incident.
Yeah chances of it returning to service are minimal, seeing as 701 (same age) is now in the 'vintage' fleet Lothian most likely won't bother repairing it. It's quite sad but I suppose it didn't have long left anyway.It'll probably be a scrapper, i can't see them repairing a 14 year old single decker. Maybe First will rivet it back together and send it to Balfron.
I might send a letter to recommend cellotape? That's likely cheaper still.It'll probably be a scrapper, i can't see them repairing a 14 year old single decker. Maybe First will rivet it back together and send it to Balfron.
You rarely see a single in KirkintillochHas that riveting First Glasgow B7RLE made it to Kirkintilloch yet? Or is it still trying to get out of Bo'ness?
From what I’ve been told in the past from guys who moved from cumbernauld depot when it closed to larbert, everything is just as bad there as it is in glasgow, making this very likely to be the same in each depot across scotland!
If you aren't a driver and don't have access to behind the scenes I find it hard to believe those can comment on the overall operation and its quality..
Perhaps I should score-out Cello-tape and write Pritt-Stick?, perhaps they could borrow some from a local Primary School..
Aberdeen being the heartland of Firsts inception I’d expect them to pull there weight, the only point of reference I have to believe they do so in the north is from your biased self, the country outside aberdeen may well not be to the same standard, indeed I believe First as a “group” have a fundamental flaw, that being that most of there vehicles aren't looked after to the extent they should be with most vehicles within Firsts arsena subjected to mediocre levels of care & repair, hence why I batter on about rivets being the poor, shoddy choice.Still, you made a sweeping accusation that wasn't true. Next you'll be using a photo of a Malta Citaro to claim one of Aberdeen's Artics has got stuck on Ellon Road...
There will be B7RLE or any bus for that matter throughout First with a similar lack of care & attention given to them.
I can only speak as a glasgow boy having used FiG many times over yet driving many of LB’s 04 plates and traveling on them also, even with a repaint those 04 plates are in better shape than many of Firsts 07, 08 and 09 plates, check out the rivet work on this Midland Bluebird Eclipse just above the back seats, won't find that nonsence on a LB.
As much as I'm led to believe these will be place holders for something newer in the future.
Just off a B7RLE on the 88, what a shoddy, rank mess of a bus!
Held together with rivets!
What a joke of a company, right alongside Stagecoach..
I am biased
When you say FiA have the worst of Scotlands fleet, that in itself rings through the ineptitude of the company from its birth place.
The damage really ain't that bad in contrast to 658 which was far far worse. A new rear window, rear cover and a touch up plus a mechanical check and it'll be fine. Probs return something like mid to late June
Id say it could be back by august earliest but your right. The rear ad wich is made from what? paper? should have burnt off if it was bad enoughThe damage really ain't that bad in contrast to 658 which was far far worse. A new rear window, rear cover and a touch up plus a mechanical check and it'll be fine. Probs return something like mid to late June
Instantly you're wrong, arguably at the moment externally Aberdeen possibly have the worst fleet in First Scotland. Much of the fleet is due for repaint (partially due to a large influx of new vehicles, repaints 5 years ago and a lack of repaints in the past year due to coach hire). The issue here is the simple fact you used the same photo twice to try and defame two different bus operators. It doesn't matter if you think First are like that nation wide, it's besides the point. It's blatant lying, the only one here with bias is you and these instances prove it.
He might have told a lie but he certainly isn't wrong. First have proved time and time again that they are incapable of repairing a vehicle properly. The amount of checkerplate I've seen holding buses together is quity simply shocking, there's no valid excuse for it whatsoever. All it takes is a quick phonecall to Wrightbus/ADL/Optare or to whoever built the bus in the first place and order the correct part and fit it properly. Not bodge it with some rivets and hope for the best.
Think you're naive to believe that a quick phonecall is all it needs and the way fleets across the country are sweated these days means that there is precious little slack in the system to have vehicles off the road.
I'd also point out that this is not just something recent. In the mid 1980s, it was common to see plates pot riveted to the base of the doors on Leyland Nationals, given the amount of corrosion. My local depot received a pair of Nationals that, for additional "comfort", had the vents on the heating pods pot riveted shut!!
Then it's the fault of the operator for not ensuring they have enough "slack" to have a vehicle off the road for proper repairs. And yes, it can actually be as simple as a phonecall to a parts supplier and getting a part sent overnight, I work in an industry where this actually happens....
Has anyone heard anything more on the new batch of XLB’s being 96 seats with a buggy space? Would give Lothian some much needed good PR!
Just reduce the legroom upstairs?Maybe they'll ask if ADL could make a slightly longer model so they can cram more seats in? 96 doesn't have the same ring to it as 100!
