Lothian Group discussion (Lothian City, Lothian Country Bus and East Coast Buses)
I'm pretty sure all 09 plate Gemini 2's are the same batch.
Am I correct in thinking the 09 plate buses were the last of the euroIV spec buses? Buses from Autumn 2009 were euroV.
So is the plan to offload anything that is not at least euroV ?
scosutsut
1 Jan 2019
scosutsut
Am I correct in thinking the 09 plate buses were the last of the euroIV spec buses. Buses from Autumn 2009 were euroV
So is plan to offload anything that is not at least euroV ?
I think all B9s are Euro 5, as Lothian's Bus2020 was about getting the whole fleet to Euro 5 or better.
For the up coming LEZ they have to be aiming for Euro 6, so B9s need equinox Euro 6 upgrades fitted, or they need to go. So I'd assume the newer B9s have got / will get that treatment, everything else will be going.
If the target remains to run vehicles to 13 years old and then dispose of them, the 09s should all leave the fleet in 2022, so I'd assume they haven't been treated and instead are going to go slightly early.
Lothian have (according the The Scotsman so believe it at your own risk) committed to Euro 6 only by the end of 2021 - ahead of the proposed LEZ introduction (2022) and LEZ enforcement (2024).
CN04NRJ
28 Nov 2019
1-10, 351-400 1000-1050 1141-1152 along with a handful (don't know which ones) of the 59 plates at Marine have been upgraded to euro 6 to my knowledge. Assume these are the buses that are staying for the meantime.
Anything else is euro 5, pretty sure all the 07 onwards B7RLEs were euro 5 too (and some of the native 04/55s?)
If that is the case then Lothian Country's 928 - 936 won't have long left either.
Why? They're a part of a different fleet.
What would need to be repainted and replaced in the Lothian fleet to facilitate this?
scosutsut
1 Jan 2019
scosutsut
The Three Bridges Tour pair 905/906 are badged externally as Euro6 from memory - would make sense, keep older assets on them given the seasonality of the work.
I don't know about the former motorhomes ones, I'm going to guess with a few repainted into LC colours they have been, and would guess 844-850 will all go over to LC when ECB get their B5TL/E400s - unless the aim is to push out the 20937-950 batch as previous comments have highlighted, they've had bruising allocations so will be higher mileage.
ECB's 10195 - 10199 and survivors from 20937-20950 (Inc 942) will need treatment or be taken off allocations that take them into the LEZ.
Graeme Duncan
3 Mar 2018
According to the tracker 900 + 916-925 are the remaining 08 B9s currently still in service.
However I find it somewhat baffling that 900 has not been withdrawn . Reason being
it is out of numerical sequence.
scosutsut
1 Jan 2019
scosutsut
I think the biggest mistake to make is to assume a bus company gives a hoot about what order they come out of service, the best examples will likely stay out the longest. Be it overall condition, mileage, length of MOT etc.
DunsBus
12 Jan 2013
Duns
Absolutely correct This waa certainly the case in LRT days, the worst examples were first to go.
ALADOU47
11 Apr 2019
I had a test drive of the Enviro today. It felt weird looking forward instead of left and right for your mirrors.
OmniCity999
30 Jan 2018
Does anybody know if 601 will be back at Lothian soon?
Strictly speaking, it hasn't been delivered yet. It's a Volvo/ADL testbed. It may conduct demonstration duties with other people first. It's not entirely confirmed yet, or atleast that I know of.
CN04NRJ
28 Nov 2019
174/175 back at Longstone. Make of that what you will... I suppose it is getting busier out there so a service change might be coming? :s (haven't checked to see if anything has been announced anywhere)
31 Jul 2020
West Lothian
It would appear that a traning bus was on Lothian Country's X27.
I don't know the accuracy of this however the map looks like it was actually on the route.
Image references.
The first image is 168 SN58 BYV on the Lothian Country fleet list on bustimes.org.
The second image is of the route map that 168 took (Edinburgh to Whitburn).
Bus9120UK
5 Oct 2019
Edinburgh
Image references.
There is a chance of a tracker swap between TB2 and another vehicle - I highly doubt it actually was on it. This, or it was used to train on route X27 and not a public run.
FlybeDash8Q400
26 Jun 2018
Edinburgh
Image references.
A training bus cannot and won’t be used on normal runs, I believe certain modifications are made in such a way that they can no longer be used in regular service until they are reverted back to how they were. A training bus normally has a second seat and parking brake added for the instructor which is in direct conflict of any passenger flow.
AVL has likely been reused and bustimes hasn’t got a record of what bus now has the AVL. As I’ve said countless times previously it’s not the most reliable source in the world for things like this.
I’m sure 168 has been modified already, and is now TB2.
CN04NRJ
28 Nov 2019
This is TB2, former 168.
cnjb8
26 Feb 2019
As said above, bustimes uses ticket machines for tracking, which operators seem to switch them around between vehicles. Bustimes is a good website, but it can lack accuracy due to this
mb88
17 Aug 2012
Image references.
I'd imagine it was used for route learning and the trainer got the driver to log onto the ticket machine to do a bit of familiarisation with that along the way.
DunsBus
12 Jan 2013
Duns
Not the first time this has happened. :) Here's one from back in the day - photo credit to VRS323, William Walker.
Olympian 770 (B770GSC), the final bus of the 1984 batch of 34 Olympians, was used by Leyland as a demonstator before finally joining its sisters in Edinburgh in June 1985. By the end of the following month, it was off again as Leyland reacquired it for use as an overseas demonstrator (in connection with a potential order from Bangkok, if my memory is correct) and supplying a replacement 770, C770SFS, with the next batch of Olympians.
The demonstration never materialised and the bus was eventually purchased by Citybus in Hong Kong, becoming their fleet number 19. Latterly serving as a driver trainer, it was finally scrapped a few years ago.
CN04NRJ
28 Nov 2019
Probably unlikely, as the bus showed up on all trackers and therefore would show up on bus stops as due etc. It would have to be logged into a running board and the AVL will deny any log on if the running board is logged into another bus.
Aaronb2601
6 Oct 2020
Private@55
Something I noticed is that on fleet numbers 401-425 and 551-570 there is a blue light that comes on above the main door when it is opened, is there any particular reason for this? Or is it just a design feature.
VioletEclipse
10 Nov 2018
Dùn Èideann
As far as I know all buses (or at least most) have an interior light above the door that only lights up when the door is opened, it uses blue LEDs on those buses hence why it lights up blue.
317 forever
21 Aug 2010
North West
Yes double deckers would sometimes appear on these routes but since Covid these routes (and service 2) became fully double deck operated. For several months Central was the only depot operating all services and 401-425, 551-570 and 441-465 were all transferred to Central from Longstone. When Longstone reopened only 551-570 returned to their original depot but others (such as the Central ex London buses) moved to Longstone. Service 22 (which was the main bus that used 441-465 at Longstone) has also remained at Central for the time being.
I had forgotten about route 2 being a recent double-deck conversion. I was expecting the ex-Go-Ahead London Volvo B9TLs on this as well as route 4. Thankfully I did track one down on route 21 instead. I realised route 22 was still at Central as I saw occasional ex-route 3 B5TLs here as well as on routes 14 & 31.
CN04NRJ
28 Nov 2019
The 2 is split between Longstone and Marine - the former working 5 of the 8 buses and the latter the 3. Strangely though a Marine bus goes off service to Broomhouse and the first 2 goes off service to The Jewel from Longstone.
On a Sunday the 2 is run fully by Longstone with 5 buses.
nesw
5 Jan 2013
New timetables from 26 June are on Traveline Scotland , yet to be confirmed by Lothian as starting then.
90019
29 May 2008
Featherstone, West Yorkshire
Sounds like when the 1 was split between Central and Longstone - after the next again service change, most of the Central buses went off service to/from Clermiston while the Longstone buses went to/from Easter Road.
CN04NRJ
28 Nov 2019
On bustimes.org as well, good to see the return of X routes and the N14. Among other changes.
