Lothian Group discussion (Lothian City, Lothian Country Bus and East Coast Buses)
Lothianbus703
2 Apr 2020
Edinburgh
Am I right in saying pre COVID Lothian used to operate a lot more single decker routes and buses (I am aware the loss of 20 63 contributed to the lower amount of single decks)?
stantheman
17 Nov 2017
Drove out on the old Turnhouse airport road ...a once lovely drive ruined by housing work and a complete mess . Did notice some bus stops though and seemed to refer to a service 68 .. not sure if this is a current or old service and who operates it .
Bus9120UK
5 Oct 2019
Edinburgh
Service 68 is operated by First, every 1 hour 10 minutes I believe? Monday - Saturday.
25 Jan 2022
Edinburgh
Think that route is operated by First Bus, although I'm not too sure on that one.
ScotRail158725
27 Nov 2018
Operated by First from Livingston every hour or so Monday to Saturday, Edinburgh city council tendered route
29 Nov 2018
Did Lothian or any of their predecessors operate a route to Turnhouse? I can't imagine this was ever commercially viable with only a handful of houses and some freight depots out that way.
FlybeDash8Q400
26 Jun 2018
Edinburgh
The last Lothian route I know of to run to Turnhouse was the 48B. When exactly it stopped or even what route it took I can’t quite remember. I do think it served Longstone though.
Baileygirl
31 Oct 2019
livingston
The 68 was operated by Waverly Travel before First. I am sure Lothian operated a 25 from St Andrews Square or Charlotte Square to Turnhouse. I remember seeing a picture of a Leyland National on it in one of the Squares.
scosutsut
1 Jan 2019
scosutsut
Just to confirm 844 is back with ECB post repaint into the new (can we call it counties?) dark green and white, complete with appropriate fleet names.
Lothian_Bus
29 Jan 2018
The 85 used to go there as well back in the 1980's and the 31 on Sunday's.
Bus9120UK
5 Oct 2019
Edinburgh
Yes. 844, 845 and 850 are all in the livery. (850 just finished) and 847 will join them within the next week. 843 is also now being prepped for paint. A few people refer to it as the "joint livery" or "racecar green livery".
scosutsut
1 Jan 2019
scosutsut
Is it looking like ECB will retain all 10 then?
scosutsut
1 Jan 2019
scosutsut
Nice one, thank you. I think on balance it makes sense to leave them be. Perhaps replace them and the ex Airlinks as one batch in the future.
Assume the more recent loans of 9xx vehicles from LCB is just temporary as paint floats, previously being covered by the hybrids?
CN04NRJ
28 Nov 2019
And what's the deal with 591-4? Surely they aren't all knackered?
11 year old early B5LHs that as far as I know haven't had the battery packs replaced. Maybe a conversion to straight diesel with a ZF box like the one GNE have done?
Maybe they would have been better off painted red and pottering about on the 12 or another easy going route in the city.
scosutsut
1 Jan 2019
scosutsut
Did they have a much easier life in LCB prior to their short stint at ECB? I would have thought the amounts of fast running would have been similar?
14 Dec 2018
Straight diesel conversion doesn't sound like a bad idea actually. After all everyone on here is always saying how short of double decks they are
The B5LH is a "parallel hybrid" system, which means at lower speeds either the motor or engine, or a blend of both, provide propulsion, and at higher speeds propulsion is provided exclusively from the engine, correct?
As opposed to for example the ADL E350H, where propulsion is always from the electric motor, and when required the engine turns a generator to supplement the power from the battery?
If so then doesn't this mean you could just isolate the propulsion battery on a B5LH and it would just perform as identical to a B5TL (albeit with the automated-manual gearbox and clutch)?
CN04NRJ
28 Nov 2019
It'd just basically be a B5TL at that point, albeit with the smaller euro 5 (4?) engine.
The GNE one had a ZF ecolife fitted in place of the i-Shift. I can't imagine how sluggish they'd be with such a small engine and that gearbox alone.
14 Dec 2018
The B5LH and B5TL both have the same size engine though..?
