tbtc
First off why is it negative to say, Lothian should have some stability for the next few months? ie let give everyone time to get used to everything so people can get comfortable, instead of causing further confusion
Possibly because, at the moment, we don't know if we are going to have a proper "second wave" or a gradual upwards recovery towards where things once were - so Lothian are running an appropriate level of service for the current situation but may have to make cuts in future or improvements - nobody know how passenger numbers are going to be (e.g. in the light of the "groups of six" announcements)
Why wasn't X38 started in Aug 2018
I dont believe Lothian should be praise for carbon copying other companies routes, that doesn't make them a leader that just makes the a follower and that isn't the Lothian way
Or should we just say change LCB sogan to Lothian country buses " we copy First bus, it's the best we can do"
So you're criticising Lothian for copying First and also... criticising Lothian for not copying First sooner?
Everything Lothian did in West Lothian gets criticised - there are complaints when they directly copy a First route - there are complaints where they provide something First aren't doing (e.g. the X18 - on the grounds that "First withdrew from that corridor many years ago, so there's clearly no demand").
I'm not saying everything they've done has been brilliant (before someone uses the tedious "fanboy" insult), but it seems a wee bit unfair to complain that they are copying First routes at the same time that you complain that they didn't start an X38 years ago...
get the X40 council tender, integrating more it's networks to other parts of Edinburgh, etc etc plenty of good ideas out there
It's a council tender - i.e. not economically viable without subsidy (same as the 20/63, which people treat as if they were gold mines) - it'd fill gap on the map between existing Lothian services but I don't think it's going to be the money spinner that people assume (plus you're dealing with reliability on the bypass etc)
