Tartan shorts
Thanks
Out of interest how do you set the screens when you take a route. I take it the screens are all numbered and the running board tells you the code(s) to enter to get the right screens showing?
Gone are the days when the 12/2 used to change number at Hay Drive and occasionally the driver would let very young me turn the handle to change the rear number.
This is a Mobitec controller for the mechanical roller blinds.
The destination, intermediate via screens and number have to be set separately on these.
The running boards have a list of the codes to use but there's some additional ones such as route diverted/part routes on the single decks that aren't listed. E.G a 30 to Musselburgh would be route 30, dest 42 and intermediate 28 (if it was a decker )
I've got a PDF file with most of them but the other evening I had to screen Western General on 171 and it took me almost 5 minutes to find it!
How are we meant to know at this point in time? Its still months before the Gemini B9s goWhen the G1/B9TLS get withdrawn will the 3 bridges ones be included or what will replace them.
all the 11 plates had seat covers redone last year however 351-363 Or 364 have the same design as their original covers instead of the updated one like the rest of them haveThe repaint order is confusing and i dont really know how its being worked out. There are still 11 plate B9's that havent had any modernisation since delivery, no new seat covers, flooring, paint or screens.
It really depends on if the tourist market picks up. We wont know the lasting damage of Covid until we're living it.When the G1/B9TLS get withdrawn will the 3 bridges ones be included or what will replace them.
in that case, people could just use the 43 with a brief walk...Just an idea but if they made it a normal service it could be a 43A.
Your own post, yes. As was i.I was referring to a recent post about 3 bridges becoming a normal bus service
The 3 Bridges is a sightseeing tour with a live guide talking about attractions on the way. It’s not a normal bus service. By having a branded livery it attracts custom.I was referring to a recent post about 3 bridges becoming a normal bus service
According to the Findlay Smith tracker LCB 591 is at Musselburgh right now and 20003 is in a field near Gullane Beach - not sure if its a bug with 2003 or did something happen?
Although this is true, I think since there have been Gemini 2's & Gemini 3's everybody has just gotten used to calling it the Gemini 1.There is no such thing as a Gemini 1 - officially it goes Gemini, Gemini 2, Gemini 3. A "Gemini 1" is something enthusiasts have created.
Thanks. Thought the same thing. I think that the MCV numbers are actually still from when the darts existed, as before the Evora's were even announced they popped up.Some of 591-594 occasionally show up on the website in North Berwick too. Most of the MCVs are showing as off the coast of Ghana and some buses used to show in the Forth so I doubt 20003 is in a field
buses in North Berwick depot show in a line near gullane, happens often overnight with what stables thereAccording to the Findlay Smith tracker LCB 591 is at Musselburgh right now and 20003 is in a field near Gullane Beach - not sure if its a bug with 2003 or did something happen?
They are 10057, 10051 & 10061 however the trackers can only contain 4 digits, but 1057, 1051 & 1061 were taken so they were changed to 3057, 3051 and 3061 on trackersDoes anyone know what type vehicle 3057, 3051 and 3061 are as they appear as being inside ECB Musselburgh Garage?
The Findlay Smith Tracker really doesn't seem accurate as others have said before.
its not really an issue as such. its a default setting where North Berwick depot sometimes auto locates to a certain latitude near the gullane area. its a similar case with of the coast of africa. on a 2D map that location is the centre of world which is where withdrawn buses etc.. defualt toFinlay Smith and bus times are both accurate with the information they get from lothians api. It's an issue with the trackers not the websites
All Edinburgh trackers share the same data feed (API), provided by Lothian and the Council.The Findlay Smith Tracker really doesn't seem accurate as others have said before.
Some of 591-594 occasionally show up on the website in North Berwick too even when I've seen them on the 287 (now 275) etc. Most of the MCVs are showing as off the coast of Ghana and some buses used to show in the Forth so I doubt 20003 is in a field
Edit: 591 has teleported to North Berwick, it is defo a bug!
Each operation has its own reference point. The entire Lothian group uses:buses in North Berwick depot show in a line near gullane, happens often overnight with what stables there
specifically vehicles that have been out of service for a long period of time/new show here.Null island in other words.
Coast of Africa is Lat 0, Long 0 hence its the default location for a lot of buses.
It was duplicated for most of its route.Forgot about that 17 route, why was that withdrawn?
pretty sure it was cut right back to Craighouse aswell before it was withdrawnIt was duplicated for most of its route.
I have found a PDF of a Lothian Buses route map from 2002, here is a screenshot of it: View attachment 87089
amazing, so many lost forgotten sights and links here
20-running the loop to Stenhouse and Chesser
