Lothian_Bus
- Joined
- 29 Jan 2018
- Messages
- 382
Apologies if already discussed. I saw 1130 in white livery earlier.
Seems more are going white, appears 1126-1130 are all white nowApologies if already discussed. I saw 1130 in white livery earlier.
a number have been painted in white - due to the PVR drop. In the future when the PVR rises again, they will be wrapped in a promotional livery - if by that point they arent being replaced.Seems more are going white, appears 1126-1130 are all white now
Along with whether the X38 will ever be seen again, that kind of speculation is another strict no-no on this thread....I'm pretty certain you wouldn't get one round Kirknewton.
When is the amazon contract finishing?a number have been painted in white - due to the PVR drop. In the future when the PVR rises again, they will be wrapped in a promotional livery - if by that point they arent being replaced.
After the Amazon contract, they'll be used in the service pool.
I'm led to believe its the 31st of January - but others who work "on the front line" so to speak may know better.When is the amazon contract finishing?
Is there a set date?
Ok thank you .I'm led to believe its the 31st of January - but others who work "on the front line" so to speak may know better.
At which time the white XLB's will run on regular service work where and when needed, until/if a PVR increase is needed on Airlink.
not entirely sure, there may be more contract work available elsewhere. Wouldnt be the first time a private hire was set up in another part of the country. etc, plenty options if the money is right.
Having high spec buses in all over white has pro's and con's, biggest pro is that they can be used on any service etc.
we still have loads.Ok thank you .
I've recently heard that E&M Horsburgh are getting rid of all their optare solo's (well at least the older gen i think) is there any other B7RLEs from Lothian (exept RIG 6491 and RUG 6492) that are there.
Yeah, Horsburgh's routes are quite rural.we still have loads.
are they actively for sale? some are. They'd be better going through Ensign though. I think Horsburgh prefer smaller buses, down to fuel costs, passenger loadings and smaller roads - so i cant imagine more B7RLE's will be for them.
sounds like a lot of speculation though. Cant imagine this is the best place to discuss Horsburgh, either.
Probably the "Indipendant Operators in the Lothians" thread.What thread should be used for speaking about E&M Horsburgh?
Thanks.
Also what B7RLE's are still with Lothian?
Ok, Thank you @OmniCity999 .Probably the "Indipendant Operators in the Lothians" thread.
Theres between 30-40 service ready examples over the seven Lothian sites. With more in storage.
Finlay Smith's site for live visual tracking
LVF for historical tracking
Finlay Smith is slightly quicker than bustimes.org as it uses a direct feed.
The 30 is fully Evora operated right now!
The buses themselves would obviously show the part route working but as it’s a temporary service alteration rather than a permanent one any live feed will run under a normal service as the data would need to be updated to reflect it, something that I imagine would take Lothian hours (or even days) to do rather than minutes.If services are being turned back before the end of their route due to weather (eg the 4 was being turned at Fairmilehead today instead of Hillend, according to the website), do they display the new terminating point on the destination display or the original? I would have thought they would display the new destination but the LVF earlier was still showing the 4s as terminating at Hillend.
Ah. So the data feed only links the vehicle to a particular rota/duty? I had assumed that all the systems were interlinked, so whatever was on the vehicles' destination screen and route number, was sent to the feed, and that was how the system found out which vehicles were running which service.The buses themselves would obviously show the part route working but as it’s a temporary service alteration rather than a permanent one any live feed will run under a normal service as the data would need to be updated to reflect it, something that I imagine would take Lothian hours (or even days) to do rather than minutes.
Ah.All the LEDs have any possible part route option programmed into them - as for the rollers I'd assume they'd be on there but I had to ask the control room for the code for Western General a few weeks ago with 173 as I've only got a few memorised.
Today, the 36 is being operated by 4 Evora's and 2 7900's. The 30 has all Evora's with one 7900 today.
Is there not an option somewhere within the depths of the various menus on the AVL (Automatic Vehicle Locator) units to program in a short turn which would then be reflected in the data feed to the various countdown websites and apps such as LVF etc? Certainly this is how it works in London with the (albeit much newer) iBus system where the driver can select from a list of curtailment points which then updates the onboard announcements etc.
Each single deck route at Longstone has at least 1 evora;
Route 2 has 4
Route 30 has 11
Route 36 has 5
Route 38 has 1
My guess is that allocations are random in the weekends due to less passengers on the buses
Or it's a case of turn up to the garage and pick a bus, any busEach single deck route at Longstone has at least 1 evora;
Route 2 has 4
Route 30 has 11
Route 36 has 5
Route 38 has 1
AIUI - buses are generally allocated to drivers. They have little to no choice as to what they are given.Or it's a case of turn up to the garage and pick a bus, any bus
*Obviously a decker if it's a decker route, or a single if it's not a decker route (especially not if it's the 30!! )
What does MUDFA stand for?Unless their on standby I believe. A mate of mine used to always pick a trident for MUDFA duties.
Multi Utilities Diversion Framework Agreement. Fairly sure it was brought in during the Renilson era. Afaik it’s basically a spare bus, in previous years normally a few were placed around the city. These days some still do that but I think majority are spare from the depots.What does MUDFA stand for?
IIRC its related to peak spare/extra buses?
