Loud rail sound on Victora Line?
heart-of-wessex
11 Jun 2005
Trowbridge
Hello all,
Out with a friend on Saturday, took the Victoria Line from Oxford Circus to Victoria, and somewhere between Oxford Circus & Green Park (I believe, or Green Park to Victoria) was a rather loud sort of rubbing sort of sound, a bit hard to describe and he said to me 'what is it making that noise?'
I couldn't answer as I don't actually know, I found a bit of the sound I'm trying to describe in this video:
Skip to 01:47 and it start's from there and carries on to 01:57 then it stops, doesn't capture the volume well but to the ear it's very loud.
Anyone know what that sound may be as he's interested to know out of curiosity.
Thank you,
James.
Hello all,
Thank you,
James.
Don’t ask for a source for this, however something in my mind rings a bell that some years ago there was a short piece of experimental track installed on the southbound between OXC and GRP.
I can’t recall its purpose, but in reality it was a short section which had a particularly distinctive (and loud!) noise - hence why it sticks in the mind as the loud noise was both very conspicuous and very distinctive. It lasted for a few seconds at line speed.
I’ve no idea if this may be related, but from memory it was more or less at the place in question. However, the sound on the recording is different, and suggests rail grinding has taken place in the area. If the experimental section is still there (this would have been early 2000s as it was going some way back into 67 stock days) then the sound may have been modified by grinding.
I have some track formation plans for LU, but I think they only cover the ex Tube Lines lines.
More recently there is an ongoing issue on LU due to the installation of a new type of track formation aimed at reduction vibration on curves in association with the advent of night Tube. Unfortunately it was successful at reducing vibration but at a cost of massively increasing noise. LU has mitigated against this by a rushed programme of rail grinding, rushed once the threat of strikes loomed not because of the massive mailbox of passenger complaints! I can’t say if this may apply to the location in question however.
big all
23 Sep 2018
redhill
worth noting
if small flats on wheels are gained on a curve due to the weight off the train leaning in that direction that specific noise will only be heard when the train wheel area damaged touches the rail head
this is because the wheel is conical and the railhead is curved so a small say 5mm bit off damage on the wheel will only be heard when that part off the wheel tread s in contact with the rail
Shaw S Hunter
21 Apr 2016
Sunny South Lancs
That sounds very much like the after effects of rail-grinding. Many years ago on a visit to family in London I experienced exactly the same, on a different stretch of the Victoria Line, and was told that LU (or LRT?) had put up notices informing passengers of this and that it would soon go away through natural wear.
TRAX
2 Dec 2015
Paris, EU
So this would be the sound of fresh rail ?
I’ve always thought/been told that this was the sound of air/wind going under the train...
TrainTube
24 Sep 2018
I believe as others have mentioned it is to do with rail grinding. There are similar sections on the South Western Mainline where there is a sound like that, much deeper and very loud from the outside.
AM9
13 May 2014
St Albans
You also get the "roaring" from rail corrugation. That's one of the things grinding is intended to rectify.
The effects of grinding has been mentioned here many times. I presume that is because the grinding head/wheel goes at right-angles to the direction of travel. Is there a particular reason why that is done or could the grinding be done at an angle - say 45 degrees which would reduce the noise as the wheels would be continuously supported by the ridges left by the grinding?
TRAX
2 Dec 2015
Paris, EU
So does the sound come from disformed track or freshly grinded track, then ? Documents that I've found online seem to suggest that damaged/corrugated rails cause that sound, so how could it logically still be audible after the grinding ?
The corrugated rails cause a different sound to the grinding. Corrugation causes a roaring sound, whilst grinding causes a whistling sound. For this specific section I think there may be a different reason - namely a different kind of track form creating the initial noise, which has then been modified by grinding. Otherwise the grinding sound would simply be fairly consistent through the section, which it isn't.
TRAX
2 Dec 2015
Paris, EU
Hmm I wouldn't mind two videos where I can compare those two sounds, to make sure we're all on the same wave length...
There are numerous grinding wheels at various angles. But there’ll always be one of them that makes that last pass. Video here:
Lewlew
15 Oct 2019
Bakerloo line in the Paddington area northbound has just been done this weekend if you want to hear it. Other stations in that area have been done last week. The grinder is stabled at Queen's Park at the moment so will be doing other parts of the line over the coming nights.
