LUL Station Supervisers?
9 Jul 2011
A few questions on these.
-What do they actually do? Are they in charge of the station?
-Does each station have one?
-Is there more than one at each station as some are manned 24hrs per day?
-How much do they earn?
-How does one become one?
Thanks in advance for any possible answers.
Daniel
5 Oct 2005
Yes they are in charge of the station, with a DUty Station Manger above them covering more than one station, and a Group Station Manager above them.
Each station is supposed to have a supervisor, yes.
Reading the question it looks as if you mean on the roster. If so then yes, of course. One person isn't there 24hrs a day, it's shift work with a number of different people.
The money they earn varies dependant on the grade of the station they are based at.
Best route to become a supervisor at the moment is to become an LU CSA and work up.
Mutant Lemming
8 Aug 2011
After a long gap without recruiting LU have have just taken on 500 CSA's (primarily to cope during the Olympics) will be a long time before they recruit again. Station Supervisors can earn around the £38'000 to £46'000 mark depending on level of competency and location. Busy Central London stations paying more than outlying quieter suburban ones.
150222
9 Jul 2011
So each station has loads of station supervisers that are on a roster? It's not just one person? Is it a difficult job? Do they work at differant times each day and does (s)he need any qualifications/basic intelligence?
Clip
28 Jun 2010
Im sure you have to be intelligent, yes.
Im guessing the roster would be a mix of earlies/lates/nights(for maintenence access) but someone will clear that up for you. I reckon you would have 4 per station maybe in the central ones?
Im not sure but going by what we have on my railway I cant see it being to different.
Daniel
5 Oct 2005
It's certainly more than 4. Even for an outlying station.
You have several staff rostered at each individual station, and then reserve staff allocated to a group of stations covering all of them for sickness/annual leave/no cover etc
Mojo
7 Aug 2005
Some stations will also have multiple supervisors on duty at any time, whether this down to rostering or minimum staffing requirements. The Congestion Control and Emergency Plans specify minimum staffing levels for all sub-surface (formerly section 12) stations. At a very minimum this will be 1 Supervisor + 1 CSA, however at larger stations this may have a Station Control Room Assistant, and multiple CSAs/Supervisors.
As has already been alluded to above, there are various competencies/licenses which a Supervisor may hold. I'm not sure exactly on the different grades, etc, but for example one may be a SSMF (ticket office/machine cash handling).
From memory, every station has a rostered Supervisor 24 hours per day, except Cannon Street.
DavyCrocket
27 Oct 2006
Some of the outlying Met stations are 'allowed' to be unstaffed during meal reliefs
Most non sub surface stations can remain open with no staff either for meal break or a whole shift or day!
There are some stations that are prioritised as a supervisor is required and some can be 'baby sat' by a CSA
Daniel
5 Oct 2005
Well, by the rule book, I suppose any non-section 12 station can be open with no members of staff.
Mojo
7 Aug 2005
Should have mentioned that! I'm aware of this situation also existing on the Central that have 30 Min breaks where there are no staff, during the day, but was just trying to get across to the OP that (almost) all stations have staff rostered throughout the night.
tsr
15 Nov 2011
Between the parallel lines
For example, little-used stations like Roding Valley often have no staff visible on either platform and no staff in the station buildings or anywhere else on site either. That particular station is almost deserted in many off-peak periods anyway.
pitdiver
22 Jan 2012
Nottinghamshire
I am ex Station Supervisor from London Underground. I started on the Met as a Booking Clerk. Then during company plan I became a Stn Sup Multifunctional. Then moved on to SS2 MF. Feel free to ask any question in addition to those already asked and I will try to answer them.
ssray
3 Sep 2011
I`m a supervisor at Euston, we have 7 rostered supervisors, usually we have 2 supervisors on duty between 0700 and 2300 each day, then after traffic hours just the one plus a station control room assistant.
I started in 2001 as a csa out at acton town, then arrived here via the rickmansworth group(ssmf/station supervisor multifunctional) one supervisor on duty at all times
Various licences held including escalator, control room etc
What do I do? this morning I retrived an Iphone from the track on platform
no6, after agreeing with the line controller that it would be better with the owner than somebody getting down to retrive it.
yesterday an old lady was quite ill and after retriving her friends from national rail, I first aided her and called an ambulance, who took her to hospital after about 25mins.
How much do I earn? about £10 less then swmbo can spend
cheers
Ray
