Failed Unit
I should be more clear, doesn't seem anything is going north of Drayton Park.Power is on over the NCL
Same power station as Kings Cross.I should be more clear, doesn't seem anything is going north of Drayton Park.
thanks. Makes sense, but a pity.Same power station as Kings Cross.
Can 801 a crawl into Kings Cross over a short unelectrified section on its single generating unit - didn't they work from Newton Aycliffe to Darlington under their own power?
OK, what should they be doing with the resources and infrastructure available to them? Marks given for showing your working out.
That was my understanding of the situation - truly the worst possible timing if the railway is to operate a socially distanced BH weekend.Services are fully reserved tomorrow
Difficult one. I would be more then happy to cram in like sardines (as long as they don’t make us wear masks). Others may not be. You could tell them not to travel. But that would be a little harsh if that person was booked on the that train.
saying that the chances of injury / death in a RTC are much higher than COVID. But that isn’t the railways problem…
4L04, 1436 Hams Hall to Felixstowe.
Failed once between Kings Dyke and Whittlesea,,got going again only to fail at Three Horseshoes.
For reference it was in Copenhagen tunnel on the up slowApparently this is the train thats brought down the wires near Finsbury Park https://www.realtimetrains.co.uk/service/gb-nr:G22258/2021-05-28/detailed
Nat Rail say incident happened 1701
The ECRO did an emergency switch off which incorporated everything from kings cross to Wood Green including the NCLAnyone know why the Moorgate services can’t run. I am assuming from the national rail website the juice needs to be turned off all the way to New Barnet / Gordon Hill. Which is a pity the Moorgate branch is getting blocked as a result. Saying that if they could keep it open. I suspect conditions will be a touch unpleasant.
Hi,Yes, if they get authority from Hitachi to start the generating unit.
If you’ve got to cram in like sardines wouldn’t masks be a somewhat sensible precaution!?
1Z99 is 67012 and is assisting with the recovery of the unit with use of an emergency coupler. Dispatched from Bounds Green earlier this evening.9J45 still stuck at sig 2068, up slow line, as at 0137 with 1Z99 (whatever that is) stuck behind - as seen on OTT
Am I imagining it, or was there an OHL failure here not long ago?
Still they've managed to empty all KX platforms which is good going.
Dellner to swing head Combination coupler adaptor expected on site 07:30 to allow class 700 to be hauled from tunnel View attachment 97199
The location of this must have been particularly bad, as it took them 5 hours to restore any power to that entire areaFor reference it was in Copenhagen tunnel on the up slow
14 hours, time will be spent making site ( in tunnel) safe getting roof access to cut off and secure pantograph, moving and securing damaged overhead line to allow failed train to be recovered, the minute the last passenger is removed from the train it becomes an empty train in an engineers possession so takes time to issue permits for safe work, earth up overheadsm get roof access equipment14 hours after incident occurred
Where did coupler come from, was there seriously not one nearer than 14 hours away.
I suppose the old approach of having an emergency coupler in guards van of every 4VEP (in case it is needed in an emergency) don’t apply anymore
I know they do. But as I said need permission from Hitachi to use it.Hi,
801 units, both 9 and 5 car have 1 GU on the 822 car.
I shunt regularly using these engines and today a 9 car 801/2 ran from KGX to Potters Bar I believe on the GU. Seen passing Bounds Green:
1z99 was lners Bounds Green thunderbird class 679J45 still stuck at sig 2068, up slow line, as at 0137 with 1Z99 (whatever that is) stuck behind - as seen on OTT
Also, first priority was the safe evacuation of the stranded GTR trains, trapped without power. I think 3 needed evacuating.14 hours, time will be spent making site ( in tunnel) safe getting roof access to cut off and secure pantograph, moving and securing damaged overhead line to allow failed train to be recovered, the minute the last passenger is removed from the train it becomes an empty train in an engineers possession so takes time to issue permits for safe work, earth up overheadsm get roof access equipment
Assisting loco can be on site in 10 minuytes but no use until overhead cables made safe and secured.i
Excuses, excuses, excuses. Once again the railway shows how utterly clueless, useless and incompetent it is with anything outside of normal running.14 hours, time will be spent making site ( in tunnel) safe getting roof access to cut off and secure pantograph, moving and securing damaged overhead line to allow failed train to be recovered, the minute the last passenger is removed from the train it becomes an empty train in an engineers possession so takes time to issue permits for safe work, earth up overheadsm get roof access equipment
It really isn't ridiculous. Do you suggest that all the legacy couplers are replaced or that there isn't any technological progress? It would appear that there is some standardisation coming but it takes time to work through.This need for/lack of compatible couplers is ridiculous in the 21st century.
The issue isn't with the legacy couplers. There were only really 2 kinds of unit couplers until 2000ish, and pretty much anything that mechanically coupled would be fine.It really isn't ridiculous. Do you suggest that all the legacy couplers are replaced or that there isn't any technological progress? It would appear that there is some standardisation coming but it takes time to work through.
