PLATFORMS 13 & 14 ONLY
Method of Working.
The normal method of working will be for trains to work in the Down-direction on the Down line, and in the Up-direction on the Up line, with passenger trains calling at the far end of each platform (i.e. beyond the mid-platform signal).
Should a train come to a stand at the mid-platform signal, conductors should not attempt to open the train doors until the train has drawn fully forwards and come to a stand at the normal end of the platform (i.e. beyond the mid platform signal). Conductors should consider advising passengers on board that the train will be drawing forwards and the doors will be opening shortly.
Once the mid-platform signal clears to a proceed aspect, the Driver may then draw the train forward and stop at the relevant stop board. It should be noted that, unless doors have been released (see below), there is no requirement to receive the RA indication from these signals.
Should it be necessary to undertake station duties in the rear platform section (e.g. due to a failed train or ill passenger on the train in the forward section), then the following must take place, provided the full length of the train is in the platform (unless SDO fitted or local door selection is utilised):
1. The Signaller, upon learning that the train in the forward section will not be moving, must contact the platform staff via the ManRail radio system and advise them of this
2. The Platform Staff must advise the Driver of the train in the rear section that the train will be required to undertake platform duties at its current location. NOTE: Platform staff must ensure that the full length of the train is in the platform prior to advising the driver of this.
3. The Driver must advise the Conductor of the need to undertake platform duties in the rear section of the platform and the Conductor must then undertake this duty, as per their Company policies and procedures.
NOTES:
(a) If a train does undertake station duties whilst stood at a mid-platform signal on platform 13 or 14, then the mid-platform signal must display either a double yellow or green aspect before being dispatched. Trains MUST NOT be dispatched on a single yellow aspect, only to be stopped again further along the platform. This also applies when the platforms are being used bi-directionally.
(b) Platform staff must manage passenger and train interface risk for any train which terminates in Platform 13 or 14 and which then continues forwards as empty coaching stock. Drivers must assess risk and if required, request that their train is dispatched using normal procedures.
