Manchester Piccadilly Trays
Legolash2o
27 Sep 2018
What are the trays at Manchester Piccadilly please? I have the feeling they are for waste.
Elecman
31 Dec 2013
Lancashire
To try and keep the ballast clean from oil leaks and human excrement from those that can’t read on non retention tank toilet trains.
Aictos
28 Apr 2009
I’m sure they had them at London Paddington too?
CeeJ
25 Jun 2017
They do! (Or did, at least) - an episode of the television programme at Paddington spent quite a while explaining the gory details!
sprinterguy
4 Mar 2010
Macclesfield
Are there still a lot of trains with non retention tanks?
At Manchester Piccadilly, up until recently it was quite a high proportion of the total as none of Northern classes 142, 150 or 156 that regularly use the station, nor classes 144 or 153 for completeness within the Northern fleet, were fitted with them. That number is decreasing as the Northern class 150s and 156s are being fitted with them as they go through their current refurbishment, and the 142s are expected to be withdrawn within a year.
That track looks old , how old you reckon?
I could be wrong, but I thought everything was quite extensively renewed during the 2002 refurbishment, which was also when the trays were installed if I remember correctly.
Ianno87
3 May 2015
Yes, that's indeed when the trays were installed; I think in the early stages of the refurb around 1998/1999.
DarloRich
Fenny Stratford
without wishing to be rude the picture clearly shows what the trays are for! There is a mixture of ordure, oil and rainwater in there and it is a HORRIBLE job to remove them
johnnychips
19 Nov 2011
Sheffield
Shoot me down, but couldn’t you have something like a giant hoover to empty them, rather than removing them?
route101
16 May 2010
That track or the joints and sleepers make them look a lot older than that .
185
29 Aug 2010
The DSM was out a few months ago putting a fire out on one of them.... guessing a train had a fuel leak, plus a discarded cigarette.
ess
9 Feb 2010
How many diesel trains without retention tanks still visit Paddington each day?
Bigfoot
2 Dec 2013
Yes they do, they retain the ones they originally had. Their contents are heated too, yum.
The one of the reasons why class 456 had their tanks removed was because they were not heated and froze in the winter. I'd suggest that most tanks are heated to keep the contents liquid, doesn't mean they are heated much above freezing. Certainly not going to be a boiling tank of daily ablutions.
tomwills98
18 Feb 2018
Bridgend
They freeze and expand in the winter which may crack the tank, then when it thaws it leaks out. I'm surprised it doesn't drain the battery overnight. Not warm enough to put a teabag in there that's for sure.
plugwash
29 May 2015
The HSTs have all been replaced by intercity express bi-modes over the last few years and as far as I can tell all the local services are run with fairly modern EMUs. so presumablly those also have tanks.
That leaves the night rivera, which is locomotive hauled MK3s, wikipedia claims the sleeping cars are fitted with controlled emmision toilets but it's not to so clear about the non-sleeping cars (though it does talk about recent new toilet fitment, which would presumablly come with retention tanks).
vlad
13 May 2018
I haven't travelled on the Night Riviera since they refurbished it.
However, a few years ago there were stickers in the toilet in the lounge car saying not to flush when the train was in a station.
Given that pretty much the first thing the stewardess said to me when I checked in was that I could use the toilet in the sleeping car at any time I'd hope they have retention tanks!
Peter Mugridge
8 Apr 2010
Epsom
The HSTs have all been replaced by intercity express bi-modes over the last few years and as far as I can tell all the local services are run with fairly modern EMUs. so presumably those also have tanks.
There are still a few 165 / 166 units turning up at Paddington daily.
Merle Haggard
20 Oct 2019
Northampton
In the late '60s - early ' 70s Euston and Paddington stations had troughs fitted on the lines of some platforms, for the use of sleeping car trains, to my certain knowledge; other stations where sleeper services started or terminated may well have been so fitted.
Bear in mind that, when sleeper services provided a wide choice of routes, passengers could board sleeper services from around 2030-2100 and remain aboard, on arrival, to around 0800 - 08.30 but the trains, particularly on the shorter routes, might not depart until nearer midnight and arrive around 05.00-06.00. The cabins in ex LMS, GW and BR Mk1 vehicles had an interesting arrangement when the call of nature had to be met before departure time, and the equipment was NOT marked 'Do not use in stations' (though it WAS marked 'not for solid matter'...) and, when used, simply discharged onto the track - hence the troughs. Arriving into Euston about 08.00 on my daily commute, a man in waterproof clothing was often to be seen working along the troughs, as the empty stock left, with a powerful hosepipe.
There was an overnight Manchester Picc - Euston train which conveyed sleeping cars. It left Manchester around midnight and arrived at Euston about 05.00 and, just possibly, this train may have been the original reason for a trough there.
Sleeper services often detached cars en route (Exeter, for instance) and the passengers in these would not be asked to vacate until about 08.00, which could be several hours after they were placed in the platform, so these locations would very likely also have troughs.
I'm fairly sure that, at least in the period mentioned, troughs were NOT provided with the purpose of collecting leaking oil or the effects of passengers ignoring the 'Do not use in stations' instructions.
