Manchester - Preston via Wigan
neonison
25 Feb 2007
Standedge, One hill, four tunnels
As the electric Manchester - Scotland TPE services go via Wigan NW I'd expect a Manchester - Preston to be valid that way as well as via Bolton.
Is a change from Wigan Wallgate to Wigan NW also valid?
Bear in mind a smattering of Victoria services actually terminate at Wigan NW.
Unless the ticket has a route printed on it which says otherwise, a ticket from Manchester to Preston is valid on any direct service between Manchester and Preston regardless of route. So yes, this is fine on a direct train. This "direct train" rule applies throughout the network.
Don't really have time to check non-direct services but I expect it would be OK.
Merseysider
Fares Advisor
22 Jan 2014
Yes, valid on that route whether it's a direct service or not.
If you want to try it out for yourself, search on National Rail Enquiries Manchester<>Preston 'via Eccles' (fast TPEs take this route) and 'avoid Eccles' (slow Northerns). Valid whichever way you go.
