thealexweb
- Joined
- 5 Jan 2014
- Messages
- 956
Pictures of the work at Manchester Victoria.
To summarise many previous posts:Good morning,
Apologies if I am going over old stuff that has already been mentioned but it has been a while since I have been on the forum and what I am about to say may already been mentioned.
I still think the plan is to electrify Stalybridge-Victoria at some point, probably during whatever they decide to do with the Trans Pennine route for a few reasons. They have recently laid new cable troughs along the line which has stickers on them warning them of 25kv cables running through them, the same cable troughs have been used on the Chat Moss lines for electrification, also at the same time a new electrical feeder station has been commissioned in the Stalybridge area. I may be putting two and two together and making five with this though. Also with the electrification now going up to an area I know as Newtown, East of Manchester so they can put electric trains into the bays it does mean there will be less disruption at Victoria if they do decide to electrify through to Stalybridge
Cheers
I thought I read somewhere that Manchester-Stalybridge and Huddersfield-Leeds electrification is being talen forward under the Transpennine Route Extension along with quadrupling of Huddersfield- Leeds and a new station at Mirfield?
Why would they need to remodel Miles Platting and Stalybridge?The big job east of Victoria will be remodelling of Miles Platting, and maybe also at Stalybridge (again).
No wires will be going up until that is done.
There is also talk of electrifying it all, if the costs can be reduced to something like NR's 2009 RUS estimates.
The target of the upgrade is to get Manchester-Leeds down to (I think) 40 minutes.
Miles Platting is currently a sharp 30mph curve hemmed in by various bridges and I think the aim is to straighten it out for higher speeds.
Would any works in the area of the former Miles Platting railway station affect the chord (Brewery Junction?) that is used by ECS from the depot at Newton Heath to and from the Ashton line?
Based on aerial views, they can't move the eastern end of the curve too far without affecting buildings outside the railway boundary. I think if they start the curve as close as they can to the existing junction it will still be within the former four-track formation until it gets to the Oldham Road bridge, so the junction itself and the curve towards Newton Heath may remain unchanged. The other side of Oldham Road across to Queens Road is wasteland and west of Queens Road looks like some sort of industry that might be relocated fairly easily, but it looks tricky to get a good curve within the constraints and new bridges would be needed over both roads. It probably also impacts the crossovers on the Victoria side of Miles Platting.I haven't seen any plans yet.
Presumably they will need a wider sweep at both ends to realign the curve.
Still UnpluggedWhat's the status of the Great Extension Lead?
Over the past week or two passing the Network rail Alliance Compound on Ashton Moss I have noticed van belonging to Keltbray Electrification. This made me wonder whether there may be some new progress towards the wiring between Newtown (Bromley Street) and Stalybridge at last. A trip up to Mossley by train today seemed to produce a little more evidence in the form of painted markers trackside and on the platforms at both Ashton and Stalybridge. I am guessing that these are probably just survey markings.
At Ashton I spotted these. Warning you may need to look quite hard to spot the white painted squares.
Due to increased workload we are seeking to recruit an OLE Engineer.
I think they want to remodel Miles Platting and Stalybridge firstAny idea when they start doing the rest of the electrification works from outside victoria to stalybridge, please?
The latest, Sept 2019, Network Rail enhancements plans document lists no further electrification in the North, so we can assume that more wires are some way off - Vic to Stalybridge perhaps in the TransPennine Rail Upgrade later this decade, Lostock-Wigan even more remote - unless there is a reversal of government policy.Any updates?
You could do most of the electrificaion foundations and mast erection bar a few hundred yard either side of Miles Platting thus only needing the gap,filling once the junction works are completed then fit the SPS and wiringVic - Stalybridge will be more complicated due to the bridge work sat Miles Platting.
Better to start off with an easy hit between Leeds and York to get into the job.
However I am sure that there is an awful lot of work surrounding the bridge site that would need to be done first before actual track disturbance takes place at MP.
Bearing in mind Rules of the Route etc could both job go ahead at the same time?
