Manchester to Altrincham
Discussion in 'Other Public Transport' started by johntea, 1 Jun 2015.
Thread Status:
  1. johntea
    johntea Established Member
    1,132
    29 Dec 2010
    Does anyone know why the trams didn't seem to be running from Manchester centre to Altrincham over the weekend? (30 - 31 May).
    I booked a cheap hotel there which was great in theory and worked well on Saturday evening as I caught the last Northern train service there from Piccadilly about 23:15.
    Not so great trying to get back on Sunday when there only seemed to be a RRB to Stockport to then have to go from there to Manchester once every 2 hours, I arrived at the interchange and jumped on a bus which said 'Piccadilly' - 1 and a half hours later I actually ended up at Piccadilly! :lol:
    Rail Forums
  3. martin2345uk
    martin2345uk Established Member
    1,128
    21 Sep 2011
    Manchester
    There was engineering works at one of the city centre tram stops... there was a bus replacement in place, a pretty shambolic one to be fair!
  4. Greybeard33
    Greybeard33 Established Member
    1,531
    18 Feb 2012
    Greater Manchester
    The Metrolink engineering work was at the Deansgate-Castlefield stop, so trams from Altrincham were only running as far as Cornbrook. There were replacement buses between Trafford Bar and Piccadilly. There should have been trams every 12 minutes from Altrincham to Trafford Bar on Sunday 31st. About 15 minutes to Trafford Bar, but I do not know how long the bus would have taken.
    There is normally a 2-hourly Northern Rail service between Altrincham and Piccadilly on Sundays, with the first train from Altrincham at 10:00. However:
    http://www.midcheshirerail.org.uk/news/may-2015-bus-replacements/
    The first RRB from Altrincham to Stockport was not until 11:00.
    The Arriva 263 bus service from Altrincham Interchange to Piccadilly Gardens runs every 30 minutes on Sundays and the scheduled journey time is 47 minutes. http://www.tfgm.com/journey_planning/RouteMaps/263.pdf
    I drove from Altrincham to Manchester at about 10:30 on the Sunday morning, and there were no traffic hold-ups. :)
  5. Shrimper
    Shrimper Member
    348
    14 Apr 2012
    There was resurfacing work taking place on Portland St which cause traffic chaos through the weekend, which caused a lot of bunching on the replacement buses
  6. johntea
    1,132
    29 Dec 2010
    Thanks for that, picked an unlucky weekend to stay over then by the looks of things! :lol:
  7. jcollins
    jcollins Veteran Member
    29,860
    23 Jan 2009
    A normal bus service from Altrincham to Manchester should take 1 hour if it was the Arriva 263 or 1 hour 10 if it was the Stagecoach X41. The X41 follows a less direct route even if it's limited stop on certain sections. By the sound of things roadworks delayed up all bus services around the Piccadilly area on the day you travelled.
    Given loadings on a weekend when trains are running would normally be too high to use a single bus I think they should have done 1 all-stops bus every 2 hours and 1 semi-fast bus every 2 hours. A side effect of that would have been Altrincham-Stockport would have had 2 buses every 2 hours and not been within a few minutes of each other.
Thread Status:
Share This Page
