Market Harborough to Fareham route change 15/4/12
t o m
7 Feb 2011
Hello
On the 15th I will be travelling from Market Harborough to Fareham. For this I usually go EMT from Market Harborough to St Pancras then get the tube to Waterloo and then SWT direct to Fareham. However on checking the train times on various sites online the suggested routes are:
Market Harborough - Leicester - Birmingham New Street - Southampton Central - Fareham
Market Harborough - St Pancras - London Victoria - Fratton - Fareham
Does anybody know why it's giving these routes? Both of which are quite longer.
As far as I can tell there is no planned engineering work that will affect this journey. I've also checked the timetable for each leg of the journey seperatley e.g. Market Harborough to St Pancras and then Waterloo to Fareham and these are both showing as normal.
lemonic
17 Sep 2010
The East Coast website is suggesting direct trains from London to Fareham as the quickest option as part of a journey from Market Harborough to Fareham via London (There are also connections offered changing at Havant). Are you sure you haven't added a via or calling at station to your search? (It could potentially have been a previous search that hasn't cleared) What website are you searching on?
t o m
7 Feb 2011
I've checked on EMT, SWT websites and the trainline app on my phone, all are saying the same thing.
142094
7 Nov 2009
Newcastle
There may be engineering work on either some of those lines or LU that weekend, which is why the booking engines are reccommending a different route.
lemonic
17 Sep 2010
I can't replicate the results you are getting, even on the East Midlands Trains website, but I have noticed that trains appear to be diverted via Richmond, Feltham and Staines between Clapham Junction and Woking, taking 45+ minutes between those two stations.
t o m
7 Feb 2011
I've checked TFL and there are no planned works on the Northern or Picaddilly that will affect my journey.
Are you putting in the 15th April for the travel date aleksander? I've checked and checked again and I'm still getting the same results.
lemonic
17 Sep 2010
I am putting in 15 April but there do appear to be engineering works causing an extended journey time just no bus replacement, between Clapham Junction and Woking.
EDIT: Actually I am now getting the same results as you, strange! The journey time is longer than the results I had previously found.
Squaddie
6 Dec 2009
Searching on National Rail for the 15th only returns the most direct route - Market Harborough to St. Pancras, across London to Waterloo and then to Fareham - other than for the 16:04 departure, which is routed via Birmingham.
t o m
7 Feb 2011
Maybe that is what is affecting the timetable. Like I said if I get times for each leg seperately they are about what I'd expect so I'll just take my usual route and hope for the best. It does say that there is a reduced service on Sunday morning and early afternoon from Waterloo but I'll be travelling in the evening. Thanks for your help.
wibble
23 Jun 2010
Unfortunately, some journey planners don't like it when SWT divert their trains via Staines! There are direct trains running from Waterloo at 35min past the hour so you'll be OK.
t o m
7 Feb 2011
I see, thanks very much!
