Market Street to Piccadilly Gardens Manchester Metrolink
Mcr Warrior
8 Jan 2009
Not sure there are two lines from Market Street to Piccadilly Gardens. IIRC, the line splits immediately on departure from Market Street station, the left hand one (in the direction of normal travel) curves round towards Piccadilly Gardens station and the right hand one crosses over the triangular delta junction before continuing towards St. Peter's Square station.
There is a set of points at the departure end of Market Street where you can go straight on to Piccadilly Gardens or turn right for Mosley Street, as Mcr Warrior has just posted. From there, there is only one track leading to each place.
Not sure why this might be, but I'd guess because in this busy pedestrian area the driver can ensure there is nobody standing on the points before calling them to the correct setting, all during the stopping time at Market Street instead of having to stop between tramstops if the facing point was closer to the triangle. It also increases capacity a bit, as a tram can go towards Piccadilly while another one is waiting on the parallel bit if some other move is preventing it continuing onto Mosley Street.
507 001
3 Dec 2008
Huyton
Those points (MKT05P for anybody particularly bothered…) change automatically on approach based on the route code in the tram’s TMS box. The design dates back to the early days of Metrolink when those points were in fact between stations, as Market Street didn’t have an inbound platform.
Mcr Warrior
8 Jan 2009
Thanks. I'd completely forgotten that Market Street station didn't originally have a platform for both directions during much of the 1990's and only served trams heading towards Victoria/Bury. (Passengers at the time travelling in the opposite direction would have probably used the nearby (no longer there, and now demolished) High Street station, just around the corner, a few dozen yards back towards Victoria).
507 001
3 Dec 2008
Huyton
Thanks. I'd completely forgotten that Market Street station didn't originally have a platform for both directions during much of the 1990's and only served trams heading towards Victoria/Bury. (Passengers at the time travelling in the opposite direction would have probably used the nearby (no longer there) High Street station, just around the corner, a few dozen yards back towards Victoria).
Exactly. Market street wasn’t pedestrianised in those days with the bus Lane running where the current island platform is. There wasn’t enough room for the road and an inbound and outbound platform on Mosley street, so high street (and arguably Mosley street) were built instead.
Ianno87
3 May 2015
The other thing to bear in mind is that there used to be a road between the two tracks - the Piccadilly bound line and the St. Peters Square bound line (And the road continued through what is the present day Market Street platform between the two tracks).
Also the wide loop for the Piccadilly bound line gives plenty of standage spare to regulate a tram awaiting access to Piccadilly Gardens in the event of a conflicting arrival from the St. Peter's Square direction; there is a "Give Way" at the entry to Piccadilly Gardens where trams from Market Street must give priority to trams from SPS (the latter, if double, cannot stand clear of the Delta Junction).
Quite surprised that's allowed, considering the number of pedestrians who wander all over them.
If I recall rightly from reading the little commemorative book about the original opening, it's done literally just as the tram reaches them, so the risk of trapping is negligible.
Ianno87
3 May 2015
Yes, it's deliberate to only switch as the tram approaches for that reason, so pedestrians have moved out of the way of the approaching tram already.
507 001
3 Dec 2008
Huyton
It’s done within the last 10m of travel before reaching the station stop mark. Same as most street running points. It’s supposed to discourage people from being on there, as you’d think an approaching 30m long, 40 ton, bright yellow tram would discourage people from walking there…
That's true, but lots of people will know (or think they know) that it's going to stop at the tramstop before it moves onto the points. And it's on the desire line of people who might be hurrying to catch the tram.
We spent a lot of time thinking about that type of hazard at places like Rochdale and Ashton.
Ianno87
3 May 2015
Has there been any actual incidents of points trappings in nearly 30 years of Metrolink operation?
I'm not aware of any, but there are no real statistics available on incidents that might not trigger a RAIB investigation (and even accident reports from the 1990s are difficult to track down). It was certainly an issue in the safety workshops I was involved in for Phase 3.
507 001
3 Dec 2008
Huyton
That’s what I was hinting at. The operation of the points is a hangover from the days before the station was there. It actually causes issues as you can’t follow another vehicle onto Market st outbound platform without getting a ‘stored demand’ on the points meaning you have to get down and swing them manually.
Changing them to an RTS demand set would cause a hell of a lot of wrong routes though.
No.
185
29 Aug 2010
But there's been plenty of Manchester's airborne garbage fell in & nearly jammed them, if I recall in 2011, the debris pit under them was dug even deeper to accommodate more junk.
40129
23 May 2014
Regarding people instinctively moving out of the way when they see a big yellow tram approaching, I remember a vaguely amusing incident involving an original Metrolink tram in the Market Street area. These trams had two horns - a standard road vehicle one and a standard railway one (the latter being much louder). The driver was trying to encourage pedestrians who seemingly didn't instinctively move out of the way of a green and whiter tram by using the road vehicle horn without much success. So, suddenly, he gave a quick blast on the loud tone of the railway horn. I've never seen so many pedestrians move out of the way so quickly
507 001
3 Dec 2008
Huyton
The new ones are the same. To be slightly pedantic however you have a street whistle and segregated horn. On the T68s they were both air operated, on the M5000s there’s a loud speaker under the cab floor that plays a recording of the whistle/horn.
Sounding the segregated horn is officially forbidden in street running areas, however sometimes it’s absolutely necessary.
Ken H
11 Nov 2018
N Yorks
I thought the horn used was set by whether the tram was in street mode or segredated mode. I think all sorts of stuff changed when the tram switched from segregated to street and vice versa, incl the horn used.
507 001
3 Dec 2008
Huyton
On a T68 in early days, yes, in 'street' or 'street without steps' the button on the Traction Brake controller sounded the street whistle (Not a Horn, an actual brass chime whistle). In 'Segregated' then the same button on the TBC sounded the Segregated horn.
In both 'Street' modes, speed was also limited to 30mph.
After the T68M programme a button was fitted to the driver's desk for the segregated horn (The trams were now expected to be able to run in traffic on the eccles line, and the street whistle isn't always loud enough against a car/bus/truck), rather than the button on the TBC. On an M5000 there are separate pedals for each.
Ianno87
3 May 2015
Yes, I distinctly remember the "Segregated" horn being blasted at St. Peters Square at a car driver who'd run a red light in front of the tram. Though in my head that was before the T68M programme (though could just be hazy memory on my part).
Ken H
11 Nov 2018
N Yorks
so what made the tram segregated? driver pressing a button, or some automatic thing? Could the driver have flicked to segregated, pressed the horn, then switched back again.
Ianno87
3 May 2015
I recall there was a turn handle on the right hand side of the cab with 3 settings:
-Street
-Street without steps (essentially as Street mode but did not depoly the steps on the rear unit in a double formation for full height platforms)
-Segregated
There used to be signs entering/leaving the street running sections to remind the driver "Change to Street / Segregated Running Mode"
I don' think the driver would have had time to change mode, press the horn, and change back again.
507 001
3 Dec 2008
Huyton
-Street
-Segregated
He would have had to pre-T68M. It was the only way of doing it I believe. Although I only really have experience of T68Ms…
A large mode selector switch on the right hand side of the driver.
K.o.R
6 Dec 2017
-Street
-Segregated
Can confirm, saw a tram driver do this a few times when the whistle wasn't getting the message across.
Ianno87
3 May 2015
Bumping old thread, but managed to remind myself of the buttons in a T68 cab (1023) at Crewe Heritage Centre yesterday.
IIRC, the horn/toot was usually activated by the thumb button on the handle of the Traction and Braking Controller (the mode select changed between the street and segregated horns). But there is a separate Green "Seg Horn" on the console, which suspiciously looks like a retro-fit.
Shown in attached pictures:
py_megapixel
5 Nov 2018
Northern England
How long is the T68 in the Heritage Centre for, or is it a permanent exhibit? I'd quite like to go and see it if I can get the chance.
Mothball
26 Nov 2018
For the foreseeable. Waiting for an extension to the Lakeside depot at Heaton Park before it and 1007 can move. Will be plenty of time to see it at Crewe for the next season or two
Ianno87
3 May 2015
Is 1007 still at Queens Road?
Mothball
26 Nov 2018
It is stored at Trafford depot. Long, long term ambitions at Heaton Park are to have 1007 at least able to move under its own power. So its been kept indoors, dry for the most of its time since withdrawal. While 1023 will remain a static exhibit
