train_spotter
- Joined
- 18 Sep 2013
- Messages
- 33
Yep, exactly same scale, large letter, right down to bottom row for 20/20 vision. You do each eye without, then each with glasses if you wear them. A near sighted reading test(I don't use glasses for reading so only one for that), then a med range test measured out to 75cm, and try to read as small as you can. The nurse was very patient so you can read at your own pace if trying to read the absolute smallest you can.
Finally a colour vision test (if your vision is fine, theres a couple in there you wont be able to read, Unless.. you are colour blind, so don't panic mid way through that you cant read two of them.
I had a re-precept for my specs, bought a 2nd pair as it will be the requirement to carry a 2nd set at all times working. I got them to do my colour test too which was all good so it put my mind at ease.
Cheers! Another question, you don't have to be suited and booted for your medical do you?
