Merseyrail Class 777 introduction updates
DanNCL
17 Jul 2017
County Durham
Definitely not a 777 if you look at the body profile. On the 777s they have your usual (tumbledown or whatever it's called) along with the "toblerone" - introduced as a weapon against people falling down the gap.
This just has flat sides.
99% sure there's been an error here somewhere.
On top of the body shape being wrong, the Windows and doors completely don't match spec AND the 777 is supposed to have a flat floor. Looks like a continental Flirt. To be fair, the Rail post doesn't actually claim that this is a photo of the 777, just that a 777 is starting to be built.
I did say in my second post that I did think it looked a bit odd. As for the rail post, if they knew it wasn't a 777 then they shouldn't have used this image on a post relating to the 777s
390112A
7 May 2017
I think that is possibly a 777 as the floor is flat and the door way does look like that shown in the concept photos i would also like to add that using external panels and just adding more stuff in general to the body shell may change it's shape.
(This is just a thought I have no engineering experience)
It’s not, the body is totally the wrong shape. It’s a Euro FLIRT or a GTW/WINK.
notlob.divad
19 Jan 2016
It also has the wrong number of windows and the incorrect numbers wither side of the door to be any of the carriages in the concept design.
However it is good to know that they are cracking on with the things, even if the picture is incorrect.
M28361M
15 May 2014
Merseyrail have announced a programme of station and line closures between October 2018 and June 2019, to prepare infrastructure for the new trains.
Please bear with us
Your brand new trains are on track for 2020. To prepare for their arrival, platform upgrade works will take place from October 2018 to June 2019, and will involve station and line closures, although we'll be running rail replacement buses during this time.
More information will be released before each closure, letting you know exactly how your station and line will be affected and how we will support you getting from A to B. You may see no difference at first, but you’ll definitely feel the benefits in the long-run.
Pioneering Platforms
This programme of works is all about getting the Merseyrail network ready for the arrival of our new groundbreaking trains. They will be faster, safer, more comfortable than ever, and able to carry 50% more passengers. Getting you there safely is at the heart of what we do. Your new trains will have extensive CCTV, the carriages will be open, light and bright and you can see right down the train. They will have wider aisles with better space for wheelchairs, bikes prams and luggage. These new trains will boost the regional economy by £70 million pounds every year, create around 1,000 new jobs, and make Merseyrail the most accessible rail network in the UK.
You will benefit from a number of modern features including sliding step technology which will result in unassisted access for all and you will be able to get on and off the trains much more easily. This technology represents a pioneering approach for the UK. We need to do some work to the platforms before the new trains arrive and in readiness for the sliding step.
Looking at the map they have provided, most lines will be closed for 1-2 weeks each, but some stations will be for longer.
IanXC
Emeritus Moderator
18 Dec 2009
I have copied this post into a new thread in Infrastructure and Stations, here: https://www.railforums.co.uk/threads/merseyrail-stations-platform-upgrade-work.168368/
If we can stick to stock discussion on this thread and infrastructure on the above one, that would be great.
Arcadia77
28 Apr 2011
I see Merseytravel have got a mock-up of the new train which the Liverpool Echo have been to visit and done an article on. Looks very smart - apparently going on display at Lime Street in November to the public.
Edited to add the correct link in!
Looks decent - pretty much a higher-floor Euro-FLIRT. I note that the cab window is no longer clear but frosted - I guess the unions won that one.
The mock-up appears to be essentially a complete vehicle above the floor rather than what you usually see (though has two doors on the end coach so isn't a totally faithful copy) - the doors in particular appear to be proper ones, with the person speaking having to hold them open as they started to auto-close.
This is the proper link by the way, the above one is to Lime St works:
https://www.liverpoolecho.co.uk/news/business/first-look-inside-futuristic-new-15031395
Lighting is interesting - as well as the standard FLIRT ceiling level cool white there seem to be additional warm white strips above the luggage rack. I'm not sure this is entirely necessary, they may be a bit bright?
Arcadia77
28 Apr 2011
Thanks - not sure how I ended up putting that link in originally?!
michael74
3 Jul 2014
Looks good, I do wonder how they will deal with the tight radius of Hamilton Square and the sliding step.
samuelmorris
18 Jul 2013
Brentwood, Essex
Smart glass evidently, according to the second video on the page. I wonder if that'll end up with a situation at some point where a train has to be taken out of service due to the cab glass being stuck in the 'transparent' setting when the driver has deemed it unsafe to continue as such. It's bound to happen at some point...
MCR247
7 Nov 2008
ICE 3s have smart glass where frosted is the default to get avoid this happening so I imagine Stadler will be using something similar
jopsuk
13 May 2008
my understanding is that most "smart glass" uses a liquid crystal layer that is opaque in the "rest" state and only goes clear when a small voltage is applied across it (with a very low current draw), so the "failure" state would always be cloudy.
Yeah, LCDs can either be "normally clear" or "normally opaque" depending on which way round you place the polarising layers either side of it. Try it with an old broken calculator if you like :)
jopsuk
13 May 2008
Hours* of fun to be had with polarised specs and LCD watches/timers/calcuclators and even many phone screens.
lyndhurst25
26 Nov 2010
And car dashboard displays - you can't read the ones on my car wearing polarising sunglasses - a bit of a stupid design error, that.
Journeyman
16 Apr 2014
Certainly looks impressive, with a lot of customer input and thought put into the design. I suspect Stadler will be winning more orders off the back of this - Tyne and Wear must be looking closely.
This is classic Stadler - build exactly what the customer wants (from simple stuff like the colour of buttons and type of seats right through to loading and track gauge) using standardised modular components.
Not the classic "you can have an Aventra, the options are what colour you paint it, the door layout, the length and what seats you put in it".
Journeyman
16 Apr 2014
It'll be interesting to see how far they can go with customisations, and how small a build is economic for it. I've never thought there was a good business case for tourist-orientated West Highland Line stock, but maybe there is!
Itching to ride an Anglia FLIRT now.
Mikey C
11 Feb 2013
Of course the real test is how well these Stadler trains work, seeing that they have little UK experience
Not that UK experience seems to have done much good to Bombardier with their Aventra problems!
Think this was missed when it was first published - looks like there is a mock-up of the new Merseyrail trains that's going to go on public display:
Not open to the public yet but seems that it'll be on display at Lime Street (wonder where they'll put it??) in November. Looks very smart - layout is quite continental.
Confused. This is the same info as posts #98, #99 and #101 made at the time surely?
They've done some very small fleets (including scenic coaches) for the Swiss narrow gauge lines.
Not a FLIRT (though Stadler have recently supplied the same operator with a smallish fleet of GTW derivatives too), but there's this - 20 LHCS coaches which are *very* custom - narrow gauge bodies but adjustable gauge bogies. Through GoldenPass services have been a long time in the making!
http://www.railjournal.com/index.ph...le-gauge-coaches-for-goldenpass-services.html
While of late they have supplied some large orders, I think they would still happily take orders of the scale that Vivarail are, i.e. one unit here, two there.
chiltern trev
28 Mar 2011
near Carlisle
RAIL 861 September 12 - September 25 2018, page 23 said - "It is currently at Make.North.Docks venue until October. It will then be moved to Pacific Road Business Hub in Birkenhead, and then the city's main station at Lime Street in November."
I contacted Make.North.Docks this morning and have the following reply -
"Unfortunately the train was only for private consultation whilst at Make North Docks however it will be open to the public over at Pacific Road, Woodside from 1st – 14th October and then at Lime Street from 5th November through to 19th November where the staff on the mock up will be happy to show everyone the features of the new trains.
I believe the opening times are 9 - 5pm but its worth giving Pacific Road a ring to check. "
I have yet to contact Pacific Road Business Hub.
stuart100100
13 Dec 2009
Had a nosey around it today at Pacific Road. Nice and bright, loads of extra space. Enjoyed sitting in the drivers cab even if all the buttons were fake
20181003_105755.jpg 20181003_105217.jpg 20181003_105105.jpg 20181003_105016.jpg 20181003_104929.jpg 20181003_104912.jpg
geoffk
4 Aug 2010
View attachment 53367 View attachment 53368 View attachment 53369 View attachment 53370 View attachment 53371 View attachment 53372
I looked at this yesterday while visiting the bus and tram event. Apart from the now obligatory hard seats it seemed to go down well with everyone. If they are to run as 8-car formations then some platforms will need lengthening.
