Merseyrail disruptions on 6th & 7th May 2012
John55
24 Jun 2011
South East
On Sunday 6th May there was a fire at the sub-station at Bank Hall at lunchtime which led to the cancellation of services from Liverpool to Ormskirk and Kirkby for the rest of the day and an interruption of 4-5 hours in services from Liverpool to Southport.
On Monday 7th services from Liverpool to Hunts Cross and Formby to Southport did not run for much of the day.
Can anyone explain why the fault at Bank Hall led to such drastic service reductions so far from the reported fault on 7th May?
John55
24 Jun 2011
South East
Bevan Price
22 Apr 2010
Does the Bank Hall sub-station supply power to the Merseyrail signalling centre located nearby at Sandhills ?
John55
24 Jun 2011
South East
I don't think so. The Wirral lines were working ok and on sunday signalling in Southport station seemed to be working ok as did the local level crossings. When the power to the signalling centre failed a couple of years ago the level crossings defaulted to shut to the roads and that didn't happen last week.
Pumbaa
19 Feb 2008
The NR response took very long - discussions will be ongoing for several months!
From what I can work out, reduction in available power led to the power available being sourced for key service areas. Formby - Southport and Liverpool - Hunts X are low key priorities; principally because they can be accessed by other transport means.
John55
24 Jun 2011
South East
I had been assuming the faults were on the LV side but from your comment the light has dawned and I now assume it was a HV fault. Does all the 11kV go to Bank Hall for distribution to the Liverpool side substations? It used to be the point were Liverpool Corporation fed the railway. I hope it wasn't one of the replacement 11kV cables which failed (the last lot was bad enough).
At least NR got power on a lot faster than during the Hillside fiasco 5 or so years ago.
Pumbaa
19 Feb 2008
I've got no idea I'm afraid - I was merely parroting the official line.
