Merseyrail Stations - Platform Upgrade Work
M28361M
15 May 2014
Merseyrail have announced a programme of station and line closures between October 2018 and June 2019, to prepare infrastructure for the new trains.
Please bear with us
Your brand new trains are on track for 2020. To prepare for their arrival, platform upgrade works will take place from October 2018 to June 2019, and will involve station and line closures, although we'll be running rail replacement buses during this time.
More information will be released before each closure, letting you know exactly how your station and line will be affected and how we will support you getting from A to B. You may see no difference at first, but you’ll definitely feel the benefits in the long-run.
Pioneering Platforms
This programme of works is all about getting the Merseyrail network ready for the arrival of our new groundbreaking trains. They will be faster, safer, more comfortable than ever, and able to carry 50% more passengers. Getting you there safely is at the heart of what we do. Your new trains will have extensive CCTV, the carriages will be open, light and bright and you can see right down the train. They will have wider aisles with better space for wheelchairs, bikes prams and luggage. These new trains will boost the regional economy by £70 million pounds every year, create around 1,000 new jobs, and make Merseyrail the most accessible rail network in the UK.
You will benefit from a number of modern features including sliding step technology which will result in unassisted access for all and you will be able to get on and off the trains much more easily. This technology represents a pioneering approach for the UK. We need to do some work to the platforms before the new trains arrive and in readiness for the sliding step.
Looking at the map they have provided, most lines will be closed for 1-2 weeks each, but some stations will be for longer.
AntoniC
28 Dec 2011
Southport
I have 3 weeks on the bus to ,ook forward to it , when they upgrade the Southport to Liverpool line !.
Its easier for more to get the bus from Southport to Liverpool (and return) then to get the RRB and then catch the train.
KevinTurvey
9 Oct 2016
I'm trying to work out what they are going to do to the platform faces; are they going to raise them or build them out to reduce the gap, and if so, does this prevent the use of other classes of train within the modified stations - I understand the new units will be of a lower internal floor level anyway.
I wonder how they are going to deal with Chester, given that other main line trains enter and use platform 7, and also the quite big drop down to platform level.
The_Engineer
24 Mar 2018
The new trains will have sliding step boards to bridge the gap between train and platform. The platform height will have to be within certain tolerance. The gap between the platform and the train should not be an issue, unless it is already excessive. I understand that the work will not change the loading gauge, so existing trains cleared for the route will not be affected.
Skie
22 Dec 2008
The map suggests that Kirkdale, Sandhills and Moorfields don't need any work doing?
Most likely because those 3 stations all had major work done to them in the past which included new platform surfaces/edging and through either planning or luck (certainly for Kirkdale, which was done in 2000) it left them at the right height for the new trains to make use of with minimal fuss.
Be interesting to see what they do at Chester, where the Merseyrail terminating platform (P7) is exceptionally low.
B&I
1 Dec 2017
Announced today that from October stations are going to have platform work to accommodate the new trains
https://www.merseyrail.org/platform-upgrade-works/platform-upgrade-network-map.aspx
Obviously this is necessary work but surely they could have undertaken the work on the Wirral loop line in Liverpool whilst they had their more recent track renewal projects ... or is this too sensible?
Almost as sensible as not having to do that work twice within a decade
DynamicSpirit
12 Apr 2012
SE London
Is work required at Maghull North?
Its only just been built.
My guess is that it's a moot point. If every other station along the Ormskirk branch needs to be closed to have the work done, then you're probably not going to get any trains along that line anyway.
urbophile
26 Nov 2015
On the Skyscraper City website it's been stated that the new Stadler Merseyrail trains (if coupled together as 8 coaches) will be too long to fit at least the underground platforms. Does anybody know any more about this and if it is actually a (very serious!) oversight or has been catered for? Extending those platforms will be impossible without HS2 levels of expenditure.
Someone may not have realised they are ‘short vehicle’ 4 car trains, only 64m long, so 16m vehicles. You would hope when coupled all the doors will still be on the platforms, even if the very end of the train isn’t...
73001
2 Jun 2010
They've been designed so that the front and rear can overhang quite a bit... It's why the doors are in the centre of the carriage at the front and back. It may need the odd signal moving etc but they will fit.
Correct, hence the end coaches having only one set of passenger doors per side.
michael74
3 Jul 2014
Due to the clearance of the single bore tunnel, I assume with DOO there will be CCTV in the cab and cameras on the platforms as the cab will be in the tunnel.
Edit... Green Lane is the same but with a very narrow platform with do not alight here signs.
Yes, the DOO will be of the modern type with bodyside cameras and cab screens.
Even with the older platform screen setup, there are a great many LU stations where the cab is just inside the tunnel when the train is at the station and have been for years.
stuart100100
13 Dec 2009
More closures happening in September and October
https://www.merseytravel.gov.uk/abo...rseyrail-network-upgrade-works-announced.aspx
Getting ready for the new trains - Next phase of Merseyrail network upgrade works announced
Published on 05/08/2019
The latest phase of upgrade works to get the Merseyrail network ready for new, state-of-the-art trains have been announced today, with a small number of Merseyrail’s Northern and Wirral line stations to be affected by a series of short-term closures in September and October.
Stations affected include Rice Lane, West Kirby, Green Lane, Hamilton Square and Chester, with disruption to services lasting between one day and 13 days depending on the works to be undertaken.
Where possible these works have been programmed to minimise disruption to passengers and lineside neighbours. This means works will take place at night or on individual platforms whilst stations remain open. Where stations are fully closed, works will be undertaken day and night and high-quality rail replacement bus services will be available to get customers where they need to go.
The upgrades are part of a rolling programme of planned works which will prepare the Northern and Wirral lines for the arrival of new state-of-the-art trains in 2020.
This element of the work involves altering the height of station platforms and realigning track to ensure the new train’s sliding step can meet the platform edge. This will provide unassisted access for all passengers including wheelchair users, passengers with mobility difficulties and those with bikes, luggage or pushchairs.
The upgrades started in October last year, with eleven phases planned in total. Each phase was delivered in quick succession to complete as much work as possible in a short period. At some stations, more work was needed than the initial surveys and design had foreseen.
The decision was made to return to these stations later this year so that other phases of work weren’t delayed, which could have caused confusion for passengers.
To date, Network Rail have completed:
  • 91 platforms at 50 stations
  • 10,000m platform tiles (copers) remodelled
  • 170,000 hours worked
  • 10,500m track realigned.
Further planned works will also be taking place from later this year and into 2020 to ensure that all stations, and associated signalling infrastructure, are geared up to accommodate the new longer trains. There will also be work to install equipment to provide a pioneering connectivity system which will include high quality on-board WiFi. More details on this will be released
The timings of this next phase of works are outlined below:
  • Rice Lane to Kirkby: line closed, 7-15 September
  • Green Lane: Chester and Ellesmere Port services will not call, 8 September – 20 October
  • Hamilton Square to Hooton : line closed until 14:00, 8 September
  • Aintree to Walton: line closed until 13:00, 15 September
  • West Kirby: platform 1 closed with all trains to operate from platform 2, 16-20 September
  • New Brighton/West Kirby to Hamilton Square: lines closed, 21-22 September
  • West Kirby to Hoylake: closed, 23-29 September
  • Southport to Formby: line closed until 13:00, 29 September
  • Birkenhead Central to Chester / Ellesmere Port: line closed, 13 & 20 October
  • Bache to Chester: line closed, 14-19 October
Passengers will find timetable information and travel advice to plan their journeys atmerseyrail.org/itshappening from Monday 5 August.
While lines are closed, Network Rail will also be undertaking upgrades to the power supply which will help to drive the powerful state-of-the-art trains thereby enabling journey time reductions of over 10% across the network.
Key advice:
  • Check before you travel
  • Plan ahead – use online journey planners at Merseyrail.org and Merseytravel.gov.uk
  • Leave plenty of time for your journey
  • Consider avoiding travelling at peak times where possible
  • Consider other travel options – including commercial buses
Wayne Menzies, Head of Rail for Merseytravel said: “This next phase of planned works will be vital in welcoming our new, state-of-the-art trains to the Liverpool City Region in 2020. I want to thank passengers not only for their continued patience and cooperation but for following the advice given which is designed to help keep them on the move.”
“We, and our partners at Merseyrail and Network Rail have worked together on this project and significant planning has taken place, to minimise disruption for passengers and people living near to stations wherever possible by having the works take place at night when the stations and wider network is not in use.
“Of course, while these works continue, high-quality rail replacement buses will be available to get people where they need to go. We also encourage customers to consider other travel options, including commercial bus services. Please check your tickets and passes before you travel.”
Andy Heath, Managing Director for Merseyrail, said: “This work is essential to prepare the network for the new state-of-the-art trains that will arrive next year, with sliding step technology that will allow unassisted access for all of our passengers.
“Plans are in place to minimise disruption as much as possible, with both high quality rail replacement buses and our staff helping passengers to complete their journey during these short phases of work."
Lucy Middleton, scheme project manager at Network Rail, said: “We’ve completed around 85% of our upgrades on the Merseyrail network to prepare platforms for the arrival of new trains and their innovative sliding step technology.
“Unfortunately, we were unable to complete all upgrade work at Rice Lane, Green Lane, West Kirby, Birkenhead North and Chester as the changes needed were more complex than we originally thought.
“We didn’t want to impact further phases in the programme and made the decision to delay this work until later in the year. We’re sorry to Merseyrail passengers for the further disruption to their journeys and would like to thank them for bearing with us.”
Skie
22 Dec 2008
Those are, iirc, traction current sections so it's all power supply upgrades (or at least the vast bulk will be). The Kirkdale section has been done overnight in stages, lots of shiny new kit around the Kirkdale area already.
Skie
22 Dec 2008
Signalling isn't being touched as far as I'm aware. If you're referring to the track circuit issues with the 8 car trains, that's in the central section which isn't seeing any closures.
From putting the various bits of info together this looks like an infill of the few tricky stations that required platform works NR hadn't planned for originally, timed with the remaining power supply upgrades to minimise the needs for a separate batch of closures.
