samuelmorris
I'd appreciate it - thanks. Hopefully the figure I've got will only be a chain or so out but I'll note it down in case railmiles doesn't return any time soon.
samuelmorris:2030319 said:I'd appreciate it - thanks. Hopefully the figure I've got will only be a chain or so out but I'll note it down in case railmiles doesn't return any time soon.
52 chains according to RailMiles, same as CallySleeper has given.
Your wish is my (and RailMiles!) command:
"Route: East Croydon to City Thameslink 10mi 69ch - generated from your selection
East Croydon, Norwood Junction, Bromley Jn, Crystal Palace, Gipsy Hill, West Norwood, Tulse Hill, Herne Hill, Loughborough Junction, Elephant & Castle, London Blackfriars, City Thameslink"
Carstairs to Motherwell (assuming direct up the WCML, which SR trains are not normally, 15m65c. If via Wishaw, which most SR trains are normally, 15m66c. Yes, a whole chain difference, to my surprise too!)
Glasgow Central to Whifflet (you don't mention from High or Low Level! From HL it's 11m14c, from LL it's 10m67c)
Moorfields to Liverpool Central (0m60c - random note, there's a lot of 60c leaps in the UK!)
Clapham Junction to Feltham (assuming direct routing, 10m74c)
West Drayton to Ealing Broadway (7m41c - I should hope you were enjoying your 165s and 166s while you still can in the Thames Valley!)
Selby to Stevenage (straight down the ECML, no deviations, 146m59c)
London Euston to Glasgow Central via Birmingham New Street (408m79c - you don't mention any other routing point, so I'm assuming no messing about in the Wolverhampton/Bescot area!)
Just remember me giving up almost an hour of my time to help you tonight, when I was going to spend time planning trips! I'm sure a tasty pint would go down beautifully...
Motherwell to Glasgow Central (Low Level) (you don't specify if you went straight up the WCML or not, which again most SR trains don't do (usually via Holytown or Airbles. Via Holytown, it's 15m40c. Via Airbles it's 13m67c)
Many thanks to CallySleeper and (especially) Techniquest
Yep - via Wishaw - hadn't noticed that!
It was High Level - pre running of the electrics on the line
Think that's bad - just found a 6 chain (yes, 0.075 miles!) leap on Edinburgh Trams! (It was St Andrew Square to York Place before coming back on the same tram again)
If "direct routing" is via North Sheen, then yes
Very much so - got to take First Class whilst one could do, too!
Straight down - it was the diversions on Hull Trains into St Pancras, but someone posted those elsewhere previously between Stevenage and STP (fortunate as the Up service involved no less than 3 reversals in the space of about 30 minutes!)
Nice straight run - called at Sandwell and Dudley and then out via Penkridge. 36L into Glasgow too = £££
It is very much appreciated - I started off the year quite organised but the last few weeks of 2014 were a bit chaotic and I got behind. Still - better than 2013's mileages which I was still updating well into Feb 2014!
Now - just one last favour to ask of someone, if I may...
It would appear it was neither!
This was the service I took - http://raildar.co.uk/timetable/journey?trainid=G51694&dt=2014-11-07
Motherwell
Mossend South Operating Jn
Mossend West Operating Jn
Bellshill
Uddingston Jn
Uddingston
Newton East Jn
Newton West Jn
Cambuslang
Rutherglen East Jn
Rutherglen Central Jn
Rutherglen
Dalmarnock
Bridgeton
Argyle Street
Glasgow Central Low Level
Anderston
Exhibition Centre Glasgow
East Jn
Partick
Could it be possible to do the mileage between Motherwell and Glasgow Central LL please?
No worries, but you do owe me either a) a favour or b) a pint
Are you sure that's right?! I did York Place-St Andrews Square when I did the trams last year and my figure is much more than that! I quote the note on my RailMiles entry:
"Distance in metres = 430 metres, which is 0.267 miles. Rounding down is in effect on all these tram moves, so mileage will not be 100% correct, but will have no over-claiming!"
I took the metres measurement from the details on this forum (linked to in the first page of this thread), so I'm assuming it's correct. The conversion to mileage came from Google.
3 reversals, that's just madness!
Ching ching! Aye that's all good then, that's the route I had.
Oh of course! 13m70c is your required answer!
Have you details on the route taken? If so I could look up the mileage figures.
RailMiles is a good product that works, I've been a subscriber for a long time and would be lost without it now!
Good to see a lot of people deciding to take notes on their mileages and motive power travelled on this year!
If you wouldn't mind looking it up then that would be very much appreciated! I just spent the last goodness knows how long with a track atlas and came up with a figure that I imagine will be terribly inaccurate so I shall certainly be looking into getting a Rail Miles subscription.
The journey was the 14:00 service from GLC to EUS (I was on from the start until WVH) on the 10th of January. The head code was 9M57 and the RTT page can be found here.
Does anyone know why RTT has mileage data for some services but not others? Thanks for the help!
Is there a 2015 table?
- Glasgow Queen St - Edinburgh via Falkirk High
- Edinbrugh to Edinbrugh via Glenrothes
http://www.realtimetrains.co.uk/train/G91611/2015/01/12/advanced
http://www.realtimetrains.co.uk/train/G98106/2015/01/12/advanced
Might be here for some time without railmiles and it's via points.
Edit: From June, I appear to be missing Stratford > Pudding Mill Lane > Canary Wharf on the DLR post-realignment and new station. Thanks all.
Hope this helps!
Thanks bb21. Unfortunately it seems I am going to end up with this problem wherever I haven't taken the shortest route.
For example this one West Croydon to London Victoria http://www.realtimetrains.co.uk/train/W77096/2015/01/13/advanced thanks
I'm up to 27191 as at 4th Sep 2014. I'll continue tomorrow...
Hi,
Would appreciate help with the following 2 journeys.
Farringdon to East Croydon, via Elephant & Castle, Loughborough Junction, Herne Hill, Tulse Hill, Streatham Common, Norbury, Selhurst.
East Croydon to London Bridge, via Selhurst, Streatham Common, Tulse Hill, North Dulwich, Peckham Rye, Queens Road Peckham
Many thanks.
Coxy
This was unbelievably helpful of you, thanks again! I'm not sure what happened around Motherwell though I know the overhead lines were down earlier on in the day. Rail Miles pricing does seem quite reasonable and it will hopefully give me consistency with my mileage figures. Using the atlas I came out at 288m 1ch for that journey which I feel could be a touch inaccurate.
10m58c according to RM
bb21 appears to have got you covered on the others at least, I was fast asleep at the time of your query on the other lot! I have no gen on the DLR re-alignment, didn't know of any changes!
11m51c
Ah, I haven't had this diversion in years! Nostalgia alert...
11m79c
No problem
You didn't come out far off the correct figure at least
