ABB125
From the May timetable change, it appears that train from Norwich will arrive at Liverpool Street at xx51. Trains from Paddington heading towards Worcester depart at xx50.
At the time I may be travelling (evening), the official transfer time between LST and PAD is 30 minutes*; added to the 15 minutes interchange time at both stations, this gives exactly one hour as the minimum connection time. Given the times I mentioned in the first sentence, I'm sure you can see my issue: there's 59 minutes between the Norwich train arriving in LST and the Worcester train departing PAD.
If I were using a flexible ticket, there wouldn't be any issues. However, I'm planning to use an advance ticket, which obviously I have to use the given itinerary for. Is there any way to manipulate/force any booking system to accept a 59 minute connection, instead of adding an extra hour?
Alternatively, what are the rules regarding cross-London transfers by Underground? Could I, for example, go from LST to PAD via, for example, a magical mystery tour of London to use up the extra hour?
Thanks.
(I can't wait for Crossrail to open; surely that will reduce the transfer time between LST and PAD?)
*I know it's 25 minutes before 1900, but that's too early for me
Thanks.
