Mixture of single and double decker operated routes
Discussion in 'Buses & Coaches' started by DanTrainMan185, 12 Jun 2019.
  1. Eyersey468
    Eyersey468 Member
    180
    14 Sep 2018
    Eyms used to have a service x4 (Hull to York via North Ferriby, Brough, South Cave, Newbald and Market Weighton) that had a single deck and double deck bus allocated, also the old x55/x56/x57 routes before the route changed a couple of years ago.
    Edited to add the 45 (Bridlington to York) and 46 (Holme on Spalding Moor/Market Weighton to York) are a mix of single and double deck
  2. LiviCrazy
    LiviCrazy Member
    52
    6 Oct 2018
    Well, just after me saying that, First have allocated one of their tiny ancient Dennis Darts onto the peak time X23. Not a great situation.
  3. Mitchell Hurd
    Mitchell Hurd Member
    491
    28 Oct 2017
    Some bus routes that are not high-profile, well used or frequent routes would have anything that a bus company had available for the route - like anything from an Optare Solo or 29-seat E200 or Dart to a double-decker.
  4. SCH117X
    SCH117X Member
    767
    27 Nov 2015
    Geminis also feature and the same mixture can be found on Route 1 workings between Harrogate and Knaresborough. The Presidents in question are almost 20 year old ex National Express vehicles albeit very smartly turned out - both routes 1 and 7 have route branded Eclipse 2s
    Sort of mixture that can turn up on Connexions X1 between Harrogate and Knaresborough on a Saturday, if you replace the Dart with an Omnciity or Solar. Monday-Friday a Solo or Enviro is pretty rare and the same Omnicity /Solar/double-decker mix can be found on the X70 to Wetherby and the X52 to Ilkley
  5. dazzler
    dazzler Member
    87
    6 Apr 2018
    York
    Apart from the 10 to Poppleton, which goes up Leeman Road, under the quite low bridge that carries the North end of the railway station. They don't allocate deckers to *that* one! Well, not twice anyway! ;)
    (On topic, the father of a friend used to be a First York driver. One morning he arrived at the depot to be told his bus for the 10 was "over there" - 30 seconds later he came back and told the booking clerk he couldn't take that bus. The clerk asked "why not", "because that's a double decker!". The clerk said "Is that a problem?" "Well," my friend's father replied, "only if you want me to bring a single decker back to the yard tonight!" :D:D)
  6. delt1c
    delt1c Member
    987
    4 Apr 2008
    Not a lot changed since SMT days, Bathgate would put out what ever was available, 27, 35, 36 all rostered for double deck could produce single decks , even coaches. Have known to leave edinburgh on a Fleetline crew operated and be transfered onto a Single deck OMO (thats what it was called in 70's) at Blackburn. 45 years + Privatisation doesnt seem to have progressed much
  7. LiviCrazy
    LiviCrazy Member
    52
    6 Oct 2018
    Today was the worst example in a while with the tiny Dennis Dart on the X23 (though later back on the 27).
    6 or 7 years ago it was awful, the number of times we got the Plaxton Profile Coaches on 27/28 and it was standing room only. And Plaxton Presidents that overheated after going up the hill to Kirknewton.
    I don’t know why they route brand services.
  8. bluenoxid
    bluenoxid Established Member
    1,942
    9 Feb 2008
    First Bradford Bradford-Pudsey-Leeds X11 is supposed to be three double deckers and three single deckers.
  9. Martin2012
    Martin2012 Member
    530
    17 Jul 2012
    At the moment the Y4 Bristol to Yate route seems to get single deckers during the week and double deckers on Sundays. Prior to April there was a period where it seemed to be fully double deck operated.
    Have definatley seen a mixture of singles and doubles on Service 19 (Cribbs Causeway to Bath) in the past but recently every time I've seen the 19 it's been double deck. Does anyone know if it's meant to be fully double deck nowadays?
  10. TheGrandWazoo
    TheGrandWazoo Veteran Member
    11,198
    18 Feb 2013
    The 19/19A/37 running pattern is supposed to be double deck using ALX400 B7TLs on a Monday to Saturday daytime. However, if they're short of deckers for whatever reason, then they will put on an Eclipse on the lightest loaded board(s). Sundays are double decked but you will often see single decks (using e200s occasionally). Evening journeys are operated by Solos in the main.
  11. Qwerty133
    Qwerty133 Established Member
    2,055
    7 Oct 2012
    Leicester/Sheffield
    Almost any route operated out of Arrivas South Wigston depot in Leicester as the current allocation policy seems to be to pull random buses out of a hat (with the ones least suitable for any route having 2 balls in the hat for that route).
  12. Wirewiper
    Wirewiper Member
    501
    14 Nov 2017
    BET & TQY
    One London example is the W13 (Leytonstone - Woodford Wells). The main allocation is CT Plus ADL Enviro200 MMCs but extra journeys on schooldays (towards Woodford am, towards Leytonstone pm) are scheduled for a double-decker.
    In Torbay, the main 22 service (South Devon College - St Marychurch or Dawlish Warren) is allocated Scania N230UD/ADL Enviro400, but evening shorts between Torquay and St Marychurch are single-deck (Dennis Dart or Optare Solo).
  13. Martin2012
    Martin2012 Member
    530
    17 Jul 2012
    Thanks ever so much for that helpful response. I didn't realise the evening journeys on the 19 were worked by solos. As a rule are they sufficient for this route in the evening or do you ever get instances where the vehicle overloads?
    I caught a 37 home this evening and had an ALX400 B7Tl (I think) but have definatley seen single deckers on that service in the past.
  14. TheGrandWazoo
    11,198
    18 Feb 2013
    I'm sure that they are fine using Solos of an evening.
    The 37 used to be single decker operated (as was the 19/19A) but it's supposed to be deckers.
  15. Deerfold
    Deerfold Established Member
    9,943
    26 Nov 2009
    The 62 regularly sees double deckers (this is a recent thing) especially at weekends. The 66 also gets occasional double deckers.
    The 662 gets double deckers when there are events on - especially at weekends when Bradford are playing at home or Bingley Music Festival is on.
  16. bussnapperwm
    bussnapperwm Member
    12
    3 Jul 2019
    Another two routes in Dudley are the 82 which usually gets NXWM 20×× B7s and ALX400s and the (24)6 which usually gets a mix of B7, Trident, E400MMC and Streetdecks.
  17. davehsug
    davehsug Member
    55
    8 Jul 2014
    First 32 Hanley-Uttoxeter is always a mix.
  18. 61653 HTAFC
    61653 HTAFC Established Member
    9,854
    18 Dec 2012
    Another planet...
    Though they have fewer and fewer deckers in active service (with more being put into storage at Honley) Yorkshire Tiger 231/232 (Huddersfield to Wakefield) and 233 (Huddersfield to Denby Dale) see deckers intermittently, particularly at school times on the 233. Wait half an hour though, and you'll see Solos and folk being left behind!
  19. 37114
    37114 Member
    6
    4 Jul 2019
    Faresaver you use a mix of Enviro 200s, Solos and ex London Volvo deckers on the X31 between Bath and Chippenham.
  20. route101
    route101 Established Member
    4,201
    16 May 2010
    Lots of routes in Glasgow like the 3 and 6 . 1c and 1 d too.
  21. PaulMc7
    PaulMc7 Member
    25
    9 Jul 2019
    Glasgow has an absolute barrelload of routes with a mix. There's these then the likes of the 19/41/46/60/60A and even the likes of the 57/57A/87/88 too. The 9 and 9A are mostly single but some doubles do pop up too
  22. route101
    4,201
    16 May 2010
    I think with the 9 , Scotstoun depot simply does not have enough deckers to make a decker route . Some routes like the 4 are almost always deckers. 38 with the new buses has improved that route though they bunch up . Some routes go single on sundays like 31
  23. Quakkerillo
    Quakkerillo Member
    513
    23 Jan 2015
    407 Sutton - Caterham in Tfl Land also is a mix. Years ago used to be only single Decker.
  24. duncanp
    duncanp Member
    642
    16 Aug 2012
    Another TfL route is 357 (Chingford Hatch - Whipps Cross)
    On Mondays - Saturdays it is operated by double deckers as it terminates in the bus station (at the Whipps Cross end of the route)
    But on Sundays it is extended into the grounds of Whipps Cross Hospital, which are unsuitable for double deckers and hence the route is opeated by single deckers.
  25. Flying Snail
    Flying Snail Member
    848
    12 Dec 2006
    Most Bus Eireann commuter routes out of Dublin see a mix of single and double decker coaches. The 126 route gets occasional double deck buses mixed in with the coaches and the short Naas-Newbridge workings for some time had an Enviro 200 single decker in regular use so it was possible to have the 4 different types on the same route at the same time.
Share This Page
