MML Electrification: progress updates
I was assuming this related to the foot crossing to the nature reserve that has a history of fatalities
Track the discussion back to #8027 and I believe we are discussing the road level crossing (with footbridge) at the station. The one in the nature reserve looks easier to replace, with ramps if necessary, though it would take a bit of land out of the reserve itself.
WideRanger
15 Jun 2016
At Attenborough, I wonder whether they might replace the level crossing altogether with a bridge somewhere further up the line, in either direction (while retaining a footbridge only at the station). There seems to be space at the Barton Lane level crossing, there is currently a footpath from there through to Attenborough village - not sure whether it could be turned into a road. Or in the opposite direction, something around the quarry. It would make the access in the centre of the village more roundabout, but maybe better than a level crossing that is closed even more than now, combined with folk south of the line who seem to like exclusivity.
Eskimo
14 Jul 2020
Leicester
I have also now seen a peg! This solitary find was in the car park opposite Sileby station, looking up towards the down fast.
The peg was in a sort of ballast well, which might be hard to notice on the photo, but was dead obvious in reality. What does the process of ‘pegging’ the ballast entail?
Archie810
25 Jan 2023
Derbyshire
I think its to mark the planned location of the catenary poles.
MML electrification related - here’s a pic from yesterday of some headspan upgrades near St Albans. I do hope that chap at bottom right is OK o_O
59CosG95
18 Aug 2013
Between Beeston (Notts) & Bedlington
Ah, what I meant was, how do they go about sticking the pegs in? What sort of plan / survey / digging are they doing for just these pegs?
Typically, a 1m^3 hole is dug to find out the type(s) of soil (and depths in that 1m hole thereof) in that given location.
The hole plans themselves are based off a non-AFC (Approved for Construction) revision of the design layout plan, with the purpose being to check if the ground is suitable for the OLE structure at the proposed location, or whether/not any tweaks to the design need to be made. Any changes then typically percolate into the AFC design.
The hole is then backfilled, with the wee peg hammered in.
The details of the soil surveys help inform what type of foundation is used; most of the time, it's just normal 610dia. or (occasionally) 762dia. driven piles.
Sometimes, very occasionally, the foundation design changes - I seem to remember that Desborough (on RS1) needed a handful of concrete foundations, where the ground was augered out, a sleeve was driven in, a reinforcement cage lowered into position, and concrete was then poured. Not being on the project myself, I don't know what the cause for the design change was (or whether concrete foundations were specified from the outset), but the general rule of thumb is that piles are the most efficient option (albeit also the noisiest.)
themiller
4 Dec 2011
Cumbria, UK
I always assumed they would just take a soil sample with an auger
If you just plunged into the ground with an auger, you’d potentially end up with the same situation as during the GW electrification where signalling and power cables were damaged because their positions were unknown.
78miles
19 May 2024
Desborough
The ORR "Letter of Authorisation" for the Kettering to Wigston OLE has recently been posted on the ORR Website:
This authorisation is for the placing in service of, • UKMS 125 Overhead Contact Line System between Kettering North Junction (SPC3 72 M 0676 YDS) to Wigston South Junction (SPC3 95 M 0350 YDS).
Just need the electric trains to go with it!
Nicholas Lewis
9 Aug 2019
Of course by the time the 810's are ready to use it NR will probably want it retested
duffield
31 Jul 2013
East Midlands
Some 810's are already (intermittently) out and about though, being tested, so they should be using the newly authorised section fairly regularly between now and when they eventually go into passenger service.
WAO
10 Mar 2019
Interesting that Wigston is termed a MPATS. Does this mean that this will be the permanent northern boundary for Braybrooke ATFS, or just temporary until wiring to Syston, the putative southern boundary for the Kegworth (AT?)FS?
WAO
D Mylchreest
10 Dec 2022
WAO
Wow! I'd be grateful for an explanation of this post
Edvid
7 Feb 2008
Here's a very brief update from NR on OLE125 progress:
OLE upgrades south of Bedford are 60% complete and we're on track to complete the work this summer. Thank you for your patience. There will be disruption this weekend, please check before you travel.
Probable answer in bold since Wigston MPATS is accompanied by a neutral section.
MPATS - Midpoint Autotransformer Site (midway between feeder stations; a boundary between traction supplies)
ATFS - Autotransformer Feeder Station (entry point for traction supplies)
In a classically-fed system they would generally be labelled Midpoint Track Sectioning Cabin (MPTSC) and Feeder Station (FS) respectively.
Also, inclusion of the Napsbury / East Hyde sites within that authorisation letter is of mild curiosity to me since they've been fully operational for almost two years.
5 Aug 2015
Norfolk
Is there a neutral section at Braybrooke? Or in another terms, does it have 1 or 2 grid supplies.
It definitely has two complete grid side supply systems, fed off two grid circuits. They were connected separately, about a year apart, it was covered earlier in the thread, the grid circuits on the two sides of the pylons across the site are separate and can be switched independently.
DDB
11 Sep 2011
If they expect to be done by June it sounds like we have a winner in the race with the introduction of the new trains so hopefully no diesel running under wires for them.
Edvid
7 Feb 2008
Not quite that soon. Weekend closures for OLE125 works are publicised up to 1 June but there are more closures booked as far as August (per @Supercoss on WNXX).
I do agree that Class 810 passenger workings probably won't need to utilise the M1-adjacent changeover zone (i.e. operate pan-down on the country-side of Mill Hill Broadway) by the time they eventually commence.
5 Aug 2015
Norfolk
Braybrooke does indeed have a neutral section, and has 2 SGTs (Super Grid Transformers) from the 400kV circuit.
Thanks!!
This means, however, that Braybrook A feeds about 25 miles of line to Sharnbrook, while Braybrook B only supplies around 13 miles to South Wigston. Does this mean Braybrook B is expected to supply through South Wigston in some N-1 situations (I know that normally Mid Point substations are only bypassed in N-2 times) - or is it likely all down to where the 400kV connections were available. It is a somewhat notable mismatch especially when fewer electric trains will be on the northern side of the feeder station.
Kneedown
29 Dec 2007
Nottinghamshire
I do agree that Class 810 passenger workings probably won't need to utilise the M1-adjacent changeover zone (i.e. operate pan-down on the country-side of Mill Hill Broadway) by the time they eventually cocommence.
I was chatting to one of our other Instructors last week who is closer to the 810 project than I am currently, and he confirmed that the power changeover boards for Sharnbrook are not going to be installed, so ac operation from Wigston right through to Pancras. The boards already in place between Elstree Tunnel and Mill Hill will be redundant before they even came into use.
A bit of a silver lining to the 810 delays.
londonmidland
22 Dec 2009
Leicester
Adjacent to a new housing development just south of Bedford, I’ve noticed a row of new OLE portals being installed.
These are set back further away from the running lines compared to the existing headspans. Is there going to be a loop installed here?
Picture below shows installation of new overhead wire equipment.
John R
1 Jul 2013
That will be for the new station at Wixams, for which there needs to be some realignment to make room for the relief line platforms.
