Somewhere on here recently, it was concluded that the feeder will be just south of Chesterfield station.
Post #3233 of 25/11/19 refers. (also 3838 and 4452)
Precisely where the line-side switches will be sited isn't stated.
WAO
Some overruns will need to be provided round the other 2 bits of the Triangle at Dore including switches for the longer term hence there will need quite a bit of survey activity there.Post #3233 of 25/11/19 refers. (also 3838 and 4452)
WAO
Certainly HS2 paying not sure if they were doing though.Wasn't there an announcement three of four years ago, well after electrification from Kettering to Nottingham and Sheffield had been dropped, that the government had commissioned HS2 Ltd (as distinct from Network Rail) to do early stages investigation or design work for electrification from Clay Cross to Sheffield, as it would be a necessary part of the link from HS2 Phase 2b to Sheffield?
says it is dependent on "Completion of Project Speed". Didn't have time to search for this, anyone know what project speed is all about? I could take a guess though.HM Treasury published its infrastructure pipeline list on 13 September.
Line 435 of the spreadsheet has an entry for North of Market Harborough electrification.
Have been driving in and out of St Albans recently and have not seen any significant work going on in the Napsbury area so far. Whole line was closed over this weekend and there were on-track machines at work on the Fasts south of St Albans and in the station. Station operations were in connection with the new footbridge works; not clear what the work to the south was for.
It's not solely a Network Rail project or only a railways project. It applies to other infrastructure projects too. It was announced by Johnson last year.Network Rail's plan to cut project delivery red tape and reduce overheads (figuratively, definitely not literally)
https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/1016758/National_Infrastructure_and_Construction_Pipeline_2021.xlsx
The minimum route stkm north of Market Harborough is around 455km* (minimal over runs) but then there is depot and siding track distances to include as well."North of Market Harborough" is budgeted for £1.45Bn. Anybody know what that is in £/km?
The spend profile makes it look like boots on the ground in second half of 23/24 with the bulk of delivery in 24/25, 25/26 and perhaps being largely complete by the end of 26/27
Also relevant to this thread is Line 390 in the for MML KO1 & 1a (electrification to Corby & Market Harborough) - appears to complete in 24/25, with a final £38m, so that perhaps suggests Summer 2024 for completion.
That's rail grinding yes? I understand the principle but how does it actually work?Rail defect removal. Quite a few bits of new rail sections on the fasts.
Thank you, I know they're busy this week on various sections of the Midland but appreciate you explaining how the process works without being too complicated!In this case, it was cutting out short sections of rail (about 10 metres) and welding in new.
However, in this case the grinder then followed on later. It’s fairly simple - it works in the same way that you might see a knife sharpened on a stone wheel. Just there’s lots of stone wheels, configured in a manner that leaves the rail with the ideal profile in cross section.
The grinding does two things - firstly it does remove a mm or two of metal where necessary to remove minor cracks and other defects. Second, the process of grinding effectively heat treats the rail surface which itself can resolve some minor defects under the surface.
It's more likely part of the works listed here:Lots of Pilling works happening and piles left lineside, between the M25 and Harper Lane Redland stone terminal. Both in the Down fast cess and up slow cess.
might be for the Napsbury Tsc as mentioned in the list of work above.
Ahh, I see - I think the Hertford Loop had similar work not too long ago. SPL were/are doing that too I believe.It’s not for Napsbury, but to improve OLE reliability in a few places where the masts are ‘less stable’. There’s also new cantilevers going in near Kentish Town.
That's because there has still been no formal announcement, just a number of straws in the wind, the latest of which is the news that the Treasury seems to be scheduling the spending of the money.Just a quick question, is the MML electrification now going to reach Sheffield? Sure I saw something in the railway press a few months back, but cannot find anything definite.
And, re Kentish Town, are the 'new' cantilevers entirely new structures, or existing structures with a new cantilever frame (or similar) on?
looked as I drove by today, these piles are just south of the 17 mile post.It's more likely part of the works listed here:
Personally, my suspicion is that overlap areas are being prioritised first, as they have a higher risk of pantograph hookover; Van Elle also specified 'portal structures' .
The first picture looks to be in the area between the M25 & Harper Lane terminal, as you say (IIRC just north of the Beningfield Drive O/B), while the RRV is egressing from the RRAP south of the old St Albans Signal Box in the second picture.
No worries! Looks like the new ones are in the 10-foot between the Up Fast and the Up&Dn Slow; I'd imagine that structure replacement on the Dn Fast would require more work, being as the masts are drilled into the retaining wall.My bad wording. New structures. In this case it’s in connection with the work to replace the slab track on the fast lines there.
Too many red wall seats at stake for it not to happen!That's because there has still been no formal announcement, just a number of straws in the wind, the latest of which is the news that the Treasury seems to be scheduling the spending of the money.
Expect an announcement on or about budget day, 27 October.
*Not to be announced. Very different.Too many red wall seats at stake for it not to happen!
It still has to happen though. If the next election in 23/24 happens, and it all looks like a PR stunt, with no action or committed expenditure, it could be really bad electorally across many seats in the North*Not to be announced. Very different.
I won't hold my breath. Its easier to find a scapegoat than complete a project. This is true for politicians of every stripe.It still has to happen though. If the next election in 23/24 happens, and it all looks like a PR stunt, with no action or committed expenditure, it could be really bad electorally across many seats in the North
