MML Electrification: progress updates
Nottingham59
10 Dec 2019
that bridge does need reconstruction.
Looking further ahead, is there any clarity about how they can get the wires under the main station buildings at Leicester and Nottingham? I'm assuming that they will have to use special measures at both locations. How does the height between rail and overbridge compare to Cardiff Intersection Bridge?
This NR bulletin shows what they did there: https://www.networkrailmediacentre....demolition-thanks-to-electric-resistant-paint
but I can't find anywhere just how much clearance there is at Cardiff.
This keeps coming up. There was a post last Tuesday pointing to the previous discussions:
Nottingham59
10 Dec 2019
Thank you. I saw that, and read the discussion after post #5195, but it seemed (to me) to be inconclusive. Which is why I asked my question.
But the MR piece referred to in post #2964 does appear to suggest that the clearance between rail and bridge at Leicester is greater than at Cardiff, without track lowering. So thank you for that.
Let's hope they just get on with it.
EDIT: But nobody has yet explained how they are going to get the required clearance between platform and pantograph at Leicester. At Cardiff there are 350 metres between the Intersection Bridge and the station; at Leicester the station overbridge and platform are adjacent.
GRALISTAIR
11 Apr 2012
Dalton GA USA & Preston Lancs
Perhaps that bit it is still at design stage even though they are plowing on with it.
Nottingham59
10 Dec 2019
Maybe they just fence off the first fifty metres of platform to give space for the contact wire to rise to a safe height? It won't be like Steventon, where high speed was the issue stopping the contact wire rising to clear the level crossing.
Bristol
Losing 50m of platform.at Leicester isn't going to go unnoticed.
On a quick measurement the platforms are about 280m and a 10-car formation of 810s is only around 230m long. Unlikely that such a formation is going to need to share the platform with anything else, and all the other passenger trains there are short enough that two can share without a problem. If I remember rightly they don't use the southern end anyway.
Yindee8191
16 Mar 2019
Last time I caught a Meridian at Leicester I’m fairly sure the front (heading Up) was right next to the stairs.
In any case, if they have to take part of the platform out of use then so be it, but ideally it would be good to avoid it for both passenger convenience and creating better flows around the station.
hwl
5 Feb 2012
There is lots of on-going work on many aspects of clearances hence I suspect no final decision on actions for at least another 2 years.
Several to throw into the mix that haven't been brought up:
a) insulated pantograph horns - very helpful as regards platforms as it gives you about another ~13cm to make the magic 2.75m
b) slab track - to enable a greater lowering depth (shallower overall compared to ballast given the sewer below)
c) insulated canopy fascia - reduces ability /probability to be in contact with live parts of pantograph (canopy rebuilds to achieve / maintain W10/12 etc), not fool proof but a good risk reducer in combination with other measures.
td97
26 Jul 2017
I don't know how Leicester compares with other electrified stations but recent electrification schemes have installed non-compliant wire heights through platforms. For example at Bolton station due to the A579 overbridge above the platforms. Yes there's a standard but if a derogation can be justified then it will be.
Of course the new developments listed above also help
WiredUp
17 May 2021
Bedford
Protection by clearance or by obstacles isn't it really?
I suppose you could also just apply lots of yellow hatching (RIS-7060-INS) as required to maintain the 3.5m standing clearance, but this would reduce the useable platform width....
Or you can just magically CSM-RA risk assess it down? (the 3.5m clearance in public areas that is...).....
Thanks for the update am enjoying seeing the progress of the grid connection. Surprised how many ancillary buildings it needs.
The view is actually somewhat different to the planning drawing, which seems to have more but smaller portable buildings or containers, (post #4290). Presumably some functions have been combined. One of the planning drawings lists individual buildings for permits, batteries, communications, relay room, and an amenities room. Then there’s a standby generator and it possibly has an associated container, fuel storage etc…
Peter Sarf
Croydon
Stairs - how about replacing the stairs with 50m long enclosed ramps to soak up the unusable part of platform. That would make platform access easier for the disabled and replace some nasty hazardous (!) steps for able bodied persons.
Nottingham59
10 Dec 2019
Yes. A pity they didn't include those in the spec for GWEP. That single omission probably cost hundreds onf millions, in the end.
Domh245
6 Apr 2013
nowhere
A 50m ramp will only get you 2.2m of rise, given requirements for rest areas and a maximum 1:20 rise, which ain't going to be much use!
10 Jan 2022
platform 1 is 280m, platform 4 is 295m. although iirc, EMR intercity only uses 2 and 3. as it stands, 10 car meridians are more than 230m, but 810s should just about fit at 10 cars. fencing off 50m, though, would bring the south end of the platforms to pretty much the bottom of the stairs - especially for platform 1. everything here seems a tight fit.
hwl
5 Feb 2012
Yes. A pity they didn't include those in the spec for GWEP. That single omission probably cost hundreds on millions, in the end.
Only developed by B&W for UK spec pantographs several years after IEP spec went out for tender though.
Circa £10k a panto head for retrofit.
There was apparently some technical reason for not immediately adopting but my memory has failed me on the detail of that!
What’s East Croydon, out of interest? Similar at Waterloo East.
At least 60m is visible in an aerial view of East Croydon, but I believe they are still considered excessive slopes. Waterloo East it varies between the 3 different ramp sections, but I think platform D seems quite a bit steeper than at Croydon.
gabrielhj07
5 May 2022
Haywards Heath
I would have thought that a rise of 2m over 50m run would be rather too shallow, and a waste of space at Leicester.
The ramps at Waterloo East are more compact, and they're not exactly Everest.
Nottingham59
10 Dec 2019
Are there any examples on the GB network where insulated canopies have been used to reduce the electrocution risk on station platforms?
AM9
13 May 2014
St Albans
They would have to be shallow enough for a wheelchair user to ascend unaided. That could be quite challenging for a less than fully fit person.
MarkyT
20 May 2012
Torbay
That's the main reason for requiring level landings every 20m or so. They can also help avoid a runaway incident for wheeled conveyances and trolleys going downhill. Many older ramps at stations are not compliant with these current new-build regulations, but have been allowed to continue in use until some major renewal or alteration triggers a reconfiguration. If a non-compliant ramp was supplemented by lifts, then it wouldn't form the sole accessible route. Part of the justification for the station facilities upgrade associated with the Croydon area remodelling is to eliminate the very busy ramps.
The Ham
6 Jul 2012
Ramps would need to be flatter than 1:20, so only 10m shorter in length (you can go steeper, but then have to put level sections in and that then takes up more space than a constant grade).
I suspect that Waterloo East would be too steep for a new ramp design unless there's an alternative route (such as lifts).
Mikey C
11 Feb 2013
Wembley Stadium (the stadium not the station) for example has replaced the iconic concrete ramps outside the stadium (facing Wembley Way) with steps as the ramps were too steep to be acceptable for wheelchair use. Not an improvement for pedestrians though...
The Ham
6 Jul 2012
...and therein lies the issue with fixing rules, in that sometimes something which didn't meet the standards is replaced with something which is worse.
baz962
8 Jun 2017
They don't use only 2 and 3. They use all platforms, although rarely P1.
gabrielhj07
5 May 2022
Haywards Heath
Was it the same person that signed off on both the failure of the ramps and the implementation of the stairs? :lol:
