GRALISTAIR
Putting gantries and masts on the piles would be a better idea
I hear you sir - I totally agree!
Do they need to put the piles in, then, when all are ready, there is a dedicated rail set that installs all the masts as it trundles along - or do the masts also get put up individually?I hear you sir - I totally agree!
If you were to lay new lines between Hendon and Elstree tunnels, could you not go further, to say the southern edge of St Albans, and have a parkway station there, then operate an all-stations LO service on the (now extended) Hendon lines and run Thameslink semi-fast, serving only the new parkway station, West Hampstead and maybe one other station?
Road traffic is appalling now in the SAC area , such that even a minor accident in the peaks causes huge backs , often lasting well over an hour. If for any reason the M25, M1 , has a serious back-up or incident - then the traffic overflows onto the local network. Carnage.
Arable Green belt for now... around Sandridgebury Lane is in the mix to be released from the green belt. However beyond that it is basically farmland for about a mile, more than enough to get up and down with 1:100 gradients that are good for freight (for the rare occasions they would use it).
Not going to happen though.
Any idea what the time saving is now?At Leicester, the Up Main on platform 3 has had its TSR took away so 40MPH working through platform 3. Impressive to hear a HST scream towards London rather than power off for 15MPH.
All other TSR are in place still as far as I’m aware.
That is great context - it's so easy to focus on the 'sexier' upgrades when these in relative terms give so much more, and for more units/stopping patterns. Are there any other examples on the MML of similar changes coming?In theory, between 38 and 44 seconds for a train around 200m long. Less for shorter trains.
In context, it’s about the same as upgrading 10 miles of line from 110 to 125.
Start of work to realign the MML through the station, to increase the linespeed by minimising the reverse curve. https://www.networkrail.co.uk/runni...et-harborough-line-speed-improvement-project/What work is being undertaken at Market Harborough this weekend, I believe it is one of the reasons for the MML weekend closure. TIA
Something that needed doing quite urgently, perhaps? That looks like a point where the future alignment will be under the other arch of the bridge, on what is the old LNW formation, if it's coming off a straightened route through the station.I see that some new rail has been laid to the North of the station but it is still on the original alignment.
It also shows there is masses of spare capacity until you reach Bedford.Planehub have available a cab ride from Nottingham to St Pancras with an HST on youtube which must only be 4/6 weeks old, it shows lots of what is going on with the MML.
Presumably these are due to (hopefully) come online after this BH weekend. I assume the LED's being replaced are interlocked in Derby PSB, while their replacements will be in the EMCC.Between Spondon and Derby there are new signals lying on the ground, ready to be installed.
There are even replacements for the existing LED’s.
2. It's getting hard to fit more services through Leicester and across Wigston Jncs (hence NR have a scheme called "Leicester Capacity")
Is Network Rail going to reinstate the line between Wigston Jnc, through the tunnels to Leicester, and also add an additional freight line to Syston Jn?
A train leaving Leicester will cross over to run down the eastern line of 3, it is the reversible Up/Down Slow. In fact I’m just watching 2L77 (1628 Leicester to Lincoln) do this on the Opentraintimes map here: https://www.opentraintimes.com/maps/signalling/spc3#T_LESTERSlightly off topic but still a MML question. Can someone explain please how Syston station works with only one platform? I know Brunel was a big fan but that was years ago.
