GRALISTAIR
A few pictures from Oakley this afternoon, courtesy of a mate that took these pictures.
Great shots - thanks very much
Absolutely! Promised in the 1980's......Hopefully one day they will find the cash to electrify the entire line.
1970s actually, possibly before then.Absolutely! Promised in the 1980's......
Is the South Junction to be a full ladder, or will it be only Up Slow to Up Fast? (I remember reading somewhere that there is a plan for down Corbys to cross to slow at Wellingborough North, up Corbys to cross to fast at Wellingborough South.)Work to install Wellingborough south junction has progressed over the weekend closure.
Thanks!It looks to be a single slip junction. And looks to go from the up slow across to down slow to up fast to down fast.
According to the recent Modern Railways article the plan is that all passenger services will normally use the fasts between Bedford and Wellingborough, where the Corby trains will cross to the slows. So the Wymington lines will only get freight and diversions which probably aren't enough to justify greater speeds (what speed is the curved alignment suitable for anyway?). I'm rather surprised these lines were't value-engineered out of the electrification.I'm a bit surprised that not a lot of enhancing is being done on the slows between Bedford and Wellingborough. They are building a 4th track between Sharnbrook and Wellingborough and I would have thought that the line speed on that particular line would be greater than the pre existing one. Of course Bedford doesn't have a fast up platform which means as soon as you go to the fasts your right back on the slows to get onto a platform, and then I suspect the trains will go back to the fasts south of Bedford.
That is not what I would call ideal, efficient or even best practice. To put a ladder either side of Wellingborough doesn't seem like a great investment.
I wonder if this means the Up Corbys cross onto the Down Slow at Wellingborough North, running "wrong line" before crossing to the Up Fast at Wellingborough South. This would avoiding having to reinstate the fourth platform - something that shows no sign of happening other than de-vegging which would be needed even if the track is put back with no platform.Is the South Junction to be a full ladder, or will it be only Up Slow to Up Fast? (I remember reading somewhere that there is a plan for down Corbys to cross to slow at Wellingborough North, up Corbys to cross to fast at Wellingborough South.)
Please don't put ideas into DfT Grayling's head.
Put it another way. If the 20 miles of double-track OLE had been put on the main lines starting at Market Harborough instead, it would have got to Leicester!Please don't put ideas into DfT Grayling's head.
I believe this no longer runs via the slow lines.There is a Corby st Pancras working in the morning which already uses the diversion lines. It runs at about 9:15am to let an inter city service over take it. Of all the times I've filmed it it's doing no more than 50mph.
Not necessarily. The structure appears to coincide with the existing signals on both the Up Fast and the Slow lines, which are well off the end of the existing platforms (if the AWS magnet is at the standard spacing the signal is over 200 yards from the camera). Keeping the signals in the same position probably reduces the risk of driver misjudgment and may avoid having to move other signals to maintain the spacing.This big signal structure appeared overnight just south off Wellingborough on the slow lines. I'm going to guess this is where the South end off the platforms will be.
According to the recent Modern Railways article the plan is that all passenger services will normally use the fasts between Bedford and Wellingborough, where the Corby trains will cross to the slows. So the Wymington lines will only get freight and diversions which probably aren't enough to justify greater speeds (what speed is the curved alignment suitable for anyway?). I'm rather surprised these lines were't value-engineered out of the electrification.. ...
Thanks - good weather for photos! Re the obstruction of views, while I sympathise, there are regrettably idiots around carrying out stupid actions which the railway needs to protect itself and passengers from.......
These pictures all taken with the aid of a ladder. I know there needs to be safety in place, but putting so much obstruction on electrified lines is just ridiculous. The WCML has loads of places that accessible and bridges with low enough walls that you can see over, yet in the new age of railway building it has be higher than 7 feet tall and extend to 30 feet wide of the track. I suppose the ladder business will see a climb in in the coming months. Where there is a will there is a way. Anyway I hope you found the pictures informative.
The EDPs have shown separate key outputs for some while, before the Hendy report rescheduling KO1 was Bedford to Corby, and KO2 was Kettering to Sheffield. That was in the plan until some time in 2016, but KO1a appeared some time in 2017. Unfortunately I haven’t got every version close to hand.
It does mean though that a power supply adequate for Corby EMUs has always been on a separate KO timeline to long distance mainline electric services - or bimodes as its turned out...
Page 34 has three milestones that are relevant (my italics)
1. Infrastructure Authorised for passenger use: prioritised electrified route - May 2020
2. Infrastructure Authorised for passenger use: full electrified route - August 2020]
3. First timetabled use - December 2020
What I think this means in the real world is that (subject to availability of stock), some/all of the Corby services could transfer to EMU in May 2020, using the "priority route", which would presumably be the fast lines from Bedford to Kettering South Junction, then cross to slow lines and on to Corby. Then in August 2020, the rest of the Corby scheme is finished (e.g.4-tracking & electrification of the slow lines from Kettering to Bedford). In December 2020, the platform lengthening etc. has all been done, leading to a re-cast of the timetable with 12-car EMUs, EMT/EMR peak-time stops at Bedford once more, and so on.
