Agreed 2+2 =5 territory.I have no info on this, but would be very surprised if the 700s go to Corby. There’s barely enough capacity in the fleet as it is.
electric trains coming to Corby = must be extending Thameslink and using 700s
If Thameslink terminate at Bedford, I would not be happy for the terminators to utilize Bedford platforms. Having THL go to Corby is a win win as it makes Bedford a through station and relieves a bit of congestion and puts that pressure onto a line which is not used north of Corby for passenger traffic and Corby already has provisions to store EMU's. Eventually, Bedford will need better provisions for storing terminating trains.
Thameslink already does terminate at Bedford.
Bedford has carriage sidings and Cauldwell depot. What on earth would be the point of extending Bedford terminators another 30 miles or so north to serve a sparsely used destination, when the whole point of TL is to focus on the busy commuter stations further south?
Yes, I know.
I really see Bedford as a critical point of concern with capacity. As it has zero relief lines or loops in either direction for freights to park up at. Ideally Bedford needs TL sidings north of Bedford so a train can do a 3 minute stop at the station and move on.
I would therefore describe it as a lose, lose, lose, lose situation.
but it might be cheaper than building new sidings at Bedford - even if the railway land is already there (is it?).
Be that as it may, the journey time would be about the same as it is now which is 69minutes. That's about 6 minutes longer than the TL Bedford fasts, the same as many of the Cambridge intermediates and about 15-20 minutes less than the TL Peterboroughs, - all three of those services use class 700s. I don't think it would be good for the main TL service which has now settled down to provide fairly reliable journeys, but as a short-term fix to a lack of suitable stock, the class 700s could easily step in and deliver.... I know a few people who travel from Wellingborough and Kettering who definitely wouldn’t appreciate the 700 seats! ...
Thameslink doing Brighton to Corby with 700 units. He said this when I asked what provision will be made for Bedford terminators if they clog up the Bedford platforms. He said they will run to Corby so it won't be a problem.
I think that the proposed diagramming of the new "EMR Electrics" services north of Bedford won't be needing the crossover at Sharnbrook to be adjusted during normal day-to-day use. As I understand it, trains are planned to use the Fasts up until the new Wellingborough South Junction, where they'll then transfer over to the Slows.
In which case you have been misinformed because that is not happening.
I suggest 99% of any discussion about T/L trains to Corby has occurred in these and other rail forums, and there’s never been any official discussion of it at all; ever since the Thameslink expanded route map was first published, (and there have been numerous versions), I’ve never ever seen Corby mentioned....I find it hard to believe that 700's under the THL brand have not been discussed going to Corby, even if it is just an idea being thrown about.
There could be some benefit for as long as Bedford has a track layout barely changed from the 1980s and most of its carriage sidings can’t accommodate 12-car trains. Only any use if there are sufficient trains, as well as suitable reversing / stabling facilities provided further north though. It wouldn’t be massively different from 12-car trains running from/to Peterborough, which is actually a similar distance from London.
There’s a pretty grotesque amount of house building in that area too
I don’t for a minute think it’s an ideal solution to anything, but operationally it’s not quite as daft as it first seems (IMO!).
Looks good @WymoWanderer! Those would in fact be the Earth Wires - the Auto-Transformer wires would require substantial insulators.On the fast lines to the South of Wymington the auto-transformer wires have been installed.
Also works for the re-signalling are proceeding with new platforms and cabinets being installed.
Will post photos when there's more to show.
View attachment 65571 View attachment 65572
I was told they will go where the NR OHLE training area is (also heard the grain store will be removed).Interesting about Jowett sidings. I cannot see anywhere 2 new lanes can go in. The only place is along where the car parking lane is.
Ah yes, my bad.Looks good @WymoWanderer! Those would in fact be the Earth Wires - the Auto-Transformer wires would require substantial insulators.
No worries - I've often confused the two myself!Ah yes, my bad.
